Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 The panel was flashing "Door" for about 20mins, now the control panel is not showing anything, the mahcine is completely dead. I've checked the power socket and the plug, both are ok.
  • 209 Answers
When the machine was flashing door this was telling you that either the door was not shut properly, try it again, or the interlock switch was faulty, chances are its probably shorted out and blown the circuit board, take care and remove the board to check for signs of blowing, if no signs then i would replace the interlock and start from there, ps i am a retired engineer and have had the same machine myself
Posted on Oct 02, 2007
SOURCE:
Hotpoint washer wont work
From the manual page 24:
'Door' is flashing in the display window...
?Shut the door firmly, until it clicks.
The symbol should now go out.
I suspect the door sensor has failed. It thinks you haven't closed the door, so it refuses to do anything at all. It's called a Door Interlock, it has a switch or sensor built into it.
First try unplugging the washer for 60 seconds and plugging back in to try to reset the controller. (Dry hands only!)
If the door interlock is a simple switch, you should be able to check it with an ohmmeter. I would check it first before buying a new one.
The part number is HPTC00085194 or C00085194, here are a couple places you can buy one. You can also find them on ebay.
Washing Machine Door Interlockby Indesit
Door Interlock Washing Machine
WASHING MACHINE DOOR INTERLOCK C00085194 design may vary
Sep 21, 2016 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860 flashing f-03
Hi.
F-03 means that there is an heating system problem.
The heating system consists in the heater element and in a thermistor, located near to the element. The parts are located behind the panel at the back of the washer. Both element and thermostat can be tested using a mulitimeter to check if they have continuity (Ohms reading across part's terminals returns infinity).
Here a movie showing how to reach the heating element:
utube.png You-Tube video "rI6yItFjzQs&feature=player_embedded#!" placeholder
Dec 17, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
All lamps flashing and display flashing 888
You board behind the control panel is blown. This is caused by either a faulty door switch or the motor. Your model number tells me it’s most likely the door switch. The control board will need replacing and the door switch.
Getting to the board is easy only three screws near the soap draw. Make sure you write which wires go where and to get to the door lock undue the door rubber
Thank you for contacting Fixya.com
Aug 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Demo mode
To fix, hold the Start Button in until it completes the full cycle about 3 mins. It should say end or something similar then start as normal.
May 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
I need to replace a door seal, Hotpoint Ultima WF860
Push the top cover to the rear and lift at the same time, then ease the control panel to the right, you will not get control panel off with the top cover in place.
This will then give you access to the front panel scews, located at the top and bottom of the panel. remove the door seal ,and door lock, then lift the front panel away.
Nov 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf860
Manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HB00503_WF840_860_865_19504206802_jan05.pdf
There is a helpline number listed near the end to give you further help
Mar 22, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860
I've the same problem with my Hotpoint washing machine WF860P giving F01 flashing on screen ,machine not working, how could over come this and make the machine work again?
Please if you know the solution let me know
Shiya
Aug 15, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
154 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
