Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA TV Red color wont display at all.
Well, were not really sure what happened, but all of a sudden one day, it wont show us Red anymore, every other color doesnt have a problem displaying, only red. HELP!!!!
  • soldier222 Oct 01, 2007
    lol, thanks for the info, but im not that smart about televisions, are those inside the case?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Posted on Oct 01, 2007
6ya staff
SOURCE:
BLACK SCREEN WITH RED ON TOP RIGHT ON SONY WEGA TELEVISION
Optic Block failure. Lamp wont help you there unfortunately. The KDF60WF655 was a good TV back in its day. Don't waste your money on repair and return the lamp if you can.
Jan 04, 2018 | Televison & Video
Hi i have a Sony tv and it doesn't turn on anymore there's only a red light flashing and the sign shows
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 975 posts to different brand TVs now.
Sep 09, 2012 | Sony FD Trinitron WEGA KV-27HS420 27" TV
My sony TV trinitron wega 42 inch picture is red. Is there any solution to remove the problem?
The problem with your TV trinitron wega is at the color adjustment section. It is located at the color board mounted at the back of the picture tube. There are variable resistors that represents the color pattern in the picture tube. Adjust the red color to low level to lower the red color.
Nov 03, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
SOny FD TRINITRON WEGA XBRKV-40XBR800....IT STARTS SOMETIMES AND THEN SHUTS OFF ALL THE SUDDEN. NOW IT WONT TURN ON BUT FOR A FEW SECONDS AND SHOWS RED LINES ON THE SCREEN AND THEN SHUTS OFF. LIGHT ON...
Hello
Your tv has problems in power regulator side, which is in the printed circuit board of the telivision. Sometimes it may due to some socket contact problems. You just contact a technician., while you cannot do it right by yourself.
Oct 16, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony Wega Model KF-50WE610 won't come on
The pop you heard might have been color weel braking and it might be stuck color weel dont move tv wont come on color weel is inside of engine you would have to replace whole engine 900-up
May 23, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Best setup for Xbox 360 for Sony 32" Tube WEGA tv
Hi, Not sure whether you are kidding or not. You don't mention the tv model so I will try to help using a KV-32FS100 as an example. You really only have 2 choices assuming you have a current model xbox 360. The component cable that comes with the xbox has 6 connectors, a green, blue, red, yellow on one part and a white and red on the other part. On the back of the tv below and to the right of the s video connector are inputs labeled Y, Pb and Pr and are colored Y is green Pb is Blue and Pr is red if they aren't colored that is the correct order. Don't connect the yellow to anything. The red and white on the other part of the cable go directly to the right of these connections. It will say audio and L and R they should also be colored but if not white is L and red is R. There is also a small switch at the xbox end of the cablewhich you need to slide to HDTV. Once you are powered up don't forget to enter the setup menu on the xbox and select the settings for your tv. Again without knowing the model most wega tvs limit the component input to 480p which was the limit of a dvd. I hope this is helps.
Jan 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Apr 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36FS76U keeps turning itself off
Due to playstation or dvd nothing will happen. 5 red flashes means jungle ic failure shows this display. Technical person only sorted out the above problem.
May 07, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
327 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
