Yuraku LCD TFT Monitor MA7BBA Wont power up
Hi brought 36 of the above monitors we now have 11 dead ones so they all seem to go pop, Yuraku will no longer fix them they will not collect them even thou RMA is faxed etc! fault must be a common diode but no one says which one? Im happy to go to Maplins and solder etc, but no idea which diode/component is faulty!
Other monitors like MA9BBG has same fault so it must be easy to find and replace, If it was one I would not bother but so many with same fault!!
Cheers and good luck!
I've had the diods problem on such a monitor recently. To fix it I had to change the fuse and two 1N4007 diods as you can see on the following page:
http://tux12.free.fr/MA7BBA-recovery.html
You will notice I mounted the replacement diods on the solder side ( second hand components with too short leads) and that only 3 diod locations are seen on the component side; the fourth is hidden under the transformer on the top side.
Hope this can still be of any help.
Posted on Jul 27, 2010
I first tested the 1N4007 diodes as per tux12's solution. In my case, these were not the faulty diodes.
Next I turned my attention to the large Schottky diodes toward the top end of the power supply. There are two SR560 diodes in parallel on the left, in parallel. (The SR560 is rated for 5 amps, and can handle a peak reverse voltage of 60 volts, RMS 42 volts) Above them is a small capacitor. On the right are two SR5100 diodes in parallel (similar to the above, but rated for a peak reverse voltage of 100 volts, with a large capacitor above them.
I removed the Schottky diodes from the circuit and tested them with a multimeter on the diode setting. On the good diodes, I had a reading in one direction and no reading in the other direction. On the bad diode I had a very low reading in both directions. This was obviously the faulty diode.
I swapped in a fast-switching BY500-800 (rated for 5 amps, max peak reverse voltage 800v, rms reverse voltage 560v - possibly overkill, but I thought I'd try it and see what happened) and that replacement seems to have done the job fine :)
Posted on Feb 01, 2011
I understand it is the schotty diodes that go s/c on the psu board SR560 component
gerry moore
Posted on Nov 16, 2009
  • Frogmelon Jan 31, 2011
    I fixed a yuraku MJ9CNK 19" monitor a few days back. One of the SR5100 schottkys had a short. Pulled a BY500-800 off of the circuit board of an old Finlux CRT television that I'd kept for spares, and replaced the SR5100 with it.
    Monitor is (for now) working perfectly :p
SOURCE:
How to unlock a gateway monitor. Tft lcd fpd1975w
2007 monitor, 11 years old.
what lock? name it? the OSD menu button dead? why not say what is locked, or does lock mean dead screen./???
hold the button. down for 10 + seconds and release.(most mon./s)
lets read your manual.... bingo there it is.
btw first google hit, amazing no?
no button lock on this model.
so what does lock mean,
power on the monitor it glows and shows a logo
and tells you there is no signal if the data cable is missing
if during (no PC) monitor power on , you press the OSD buttons
you will get a OSD menu, from the monitors cpu brain.
if not the monitor is dead.
many 2007 monitors up to 2010
have CCFL back lamp, and most are dead now.
end of life dead, the flash light trick proves this on an stuck black screen (see data, yes, CCFL are dead) RIP.
https://www.manualslib.com/download/270479/Gateway-Fpd1975w.html
Sep 21, 2018 | Gateway Computers & Internet
Looking for the plug in harness for a Nitro bmwx 33.2 where can I get 8th?
BMWx-33.2W :: 3.2" Widescreen Head Units, Digital TFT ...
www.nitroelectronics.com > Car Electronics > Car Video
HEAD UNITS Digital TFT One DIN Widescreen 3.2" BMWX-33.2 By Nitro. ... Camera Input (without camera); 4 Channel High Power Output; Plug-In Harness ...
One Din with Monitor - NITRO-AUDIO
www.nitro-audio.com/one-din-with-monitor.html
BMWX-3.2 3.2" Digital TFT One DIN Widescreen/Touch Screen ... Plug-In Harness • NTSC/PAL System Compatible ... BMWX-33.2W 3.2" Digital TFT One DIN ...
NITRO BMWX 5393BT Car Stereo Bench test - YouTube
? 1:36
https://www.youtube.com/watch?v=PHjoXd55mTo
Mar 11, 2013 - Uploaded by colorado4wheeling
Looking online i couldnt find anything about this unit , except for the stock ... Looking at the devic ...
Dec 09, 2015 | Cars & Trucks
Tft
check the power cord, set to the monitor correctly, if still dead, open the monitor, check the power supply module, find some capacitor inside it, if became puffed or leaked change with new one.
Jul 17, 2013 | Samsung SyncMaster 931B 19" LCD Monitor
Where do i find a power plug for an older model
how about the plug size, normally, it comes with 2.0/2.5mm?? it looks like 15" lcd monitor and i think it is compatible with 12V 4.0~5.0A.
Mar 22, 2010 | Samsung SyncMaster 570 V (Ivory) 15 in....
Heard pop and had burnt smell from DELLE207WFP.
Hello
The pop you heard was probably a capasitor. If i am correct the smell will get more prominet how longer the screen is on.
If it is a capasitor, which i believe it is, it will not be expensive at all to repair. Just take it to an electronic repair shop and let them just put in a new capasitor. The vapours of the smell is not deadly fo the small amounts of time and the concentration you are inhaling, but it gives me headaches.
Please rate this.
Best regards
Sep 25, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Cant find Compaq TFT 1701 Monitor Manual or driver
You can download the manuals for your monitor from HP HERE
You don't have to register.
Feb 21, 2009 | Compaq TFT7020 (Carbon, Silver) 17" LCD...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor gone dead
does your tower turn on? just check if the monitor is the cause of the problem..
Jan 20, 2008 | Gateway FPD2275W LCD Monitor
Dell 1703 FPi 17" TFT LCD Flat Panel
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Sep 06, 2007 | Dell 1703FPt 17" TFT LCD Flat Panel...
Open Questions:
POGO GAMES +1800246-7609 CUSTOMER Care PhOnE NuMbEr VK VK Get easy steps to forgot or change POGO GAMES CUSTOMER CARE CARE via phone number#1-800 246 7609 just follow some steps to recover POGO GAMES CUSTOMER while you want. In varoius conditions many people lost their account CUSTOMER and much more secure information or information may be hacked by anyone so in that case people want to configure POGO GAMES with POGO GAMES or other microsoft account services. Their are man one number in easy mode wih simple procedure. Hence search engine suggest many combinations to CARE y certified POGO GAMESr to suggest people that how to change or CARE POGO GAMES voic EMAIL CUSTOMER using ph POGO GAMES CUSTOMER to CARE or change it quickly, if you have any of them so contact to get well POGO GAMES care form us. POGO GAMES CUSTOMER CARE not working POGO GAMES CUSTOMER CARE phone number POGO GAMES CUSTOMER CARE contact number POGO GAMES CUSTOMER CARE help POGO GAMES CUSTOMER CARE care POGO GAMES CUSTOMER CARE wont work POGO GAMES CUSTOMER CARE wont work POGO GAMES CUSTOMER CARE link POGO GAMES CUSTOMER CARE issues POGO GAMES CUSTOMER CARE usa POGO GAMES CUSTOMER CARE customer service. POGO GAMES EMAIL account CUSTOMER CARE ' free POGO GAMES EMAIL CUSTOMER CARE ' cannot CARE POGO GAMES EMAIL CUSTOMER ' POGO GAMES EMAIL CUSTOMER CARE ' POGO GAMES EMAIL CUSTOMER CARE download ' POGO GAMES EMAIL CUSTOMER CARE software ' free POGO GAMES EMAIL CUSTOMER CARE. POGO GAMES EMAIL CUSTOMER change, POGO GAMES EMAIL hacked CUSTOMER changed, POGO GAMES EMAIL hacked can't change CUSTOMER, change POGO GAMES EMAIL CUSTOMER on iphone, change POGO GAMES EMAIL CUSTOMER on ipad, change MICROSOFT POGO GAMESe mail CUSTOMER on android, POGO GAMES EMAIL account hacked can't change CUSTOMER, how to change POGO GAMES EMAIL CUSTOMER on droid, POGO GAMES EMAIL CUSTOMER problems, POGO GAMES EMAIL CUSTOMER not working, POGO GAMES EMAIL account CUSTOMER CARE. POGO GAMES CUSTOMER CARE phonenumber. VIKKI
Jun 24, 2019 | Microsoft Computers & Internet
POGO +1800246-7609 CUSTOMER Care PhOnE NuMbEr VK VK Get easy steps to forgot or change POGO CUSTOMER CARE CARE via phone number#1-800 246 7609 just follow some steps to recover POGO CUSTOMER while you want. In varoius conditions many people lost their account CUSTOMER and much more secure information or information may be hacked by anyone so in that case people want to configure POGO with POGO or other microsoft account services. Their are man one number in easy mode wih simple procedure. Hence search engine suggest many combinations to CARE y certified POGOr to suggest people that how to change or CARE POGO voic EMAIL CUSTOMER using ph POGO CUSTOMER to CARE or change it quickly, if you have any of them so contact to get well POGO care form us. POGO CUSTOMER CARE not working POGO CUSTOMER CARE phone number POGO CUSTOMER CARE contact number POGO CUSTOMER CARE help POGO CUSTOMER CARE care POGO CUSTOMER CARE wont work POGO CUSTOMER CARE wont work POGO CUSTOMER CARE link POGO CUSTOMER CARE issues POGO CUSTOMER CARE usa POGO CUSTOMER CARE customer service. POGO EMAIL account CUSTOMER CARE ' free POGO EMAIL CUSTOMER CARE ' cannot CARE POGO EMAIL CUSTOMER ' POGO EMAIL CUSTOMER CARE ' POGO EMAIL CUSTOMER CARE download ' POGO EMAIL CUSTOMER CARE software ' free POGO EMAIL CUSTOMER CARE. POGO EMAIL CUSTOMER change, POGO EMAIL hacked CUSTOMER changed, POGO EMAIL hacked can't change CUSTOMER, change POGO EMAIL CUSTOMER on iphone, change POGO EMAIL CUSTOMER on ipad, change MICROSOFT POGOe mail CUSTOMER on android, POGO EMAIL account hacked can't change CUSTOMER, how to change POGO EMAIL CUSTOMER on droid, POGO EMAIL CUSTOMER problems, POGO EMAIL CUSTOMER not working, POGO EMAIL account CUSTOMER CARE. POGO CUSTOMER CARE phonenumber. VIKKI
QUICKHEAL +1800246-7609 CUSTOMER Care PhOnE NuMbEr VK VK Get easy steps to forgot or change QUICKHEAL CUSTOMER CARE CARE via phone number#1-800 246 7609 just follow some steps to recover QUICKHEAL CUSTOMER while you want. In varoius conditions many people lost their account CUSTOMER and much more secure information or information may be hacked by anyone so in that case people want to configure QUICKHEAL with QUICKHEAL or other microsoft account services. Their are man one number in easy mode wih simple procedure. Hence search engine suggest many combinations to CARE y certified QUICKHEALr to suggest people that how to change or CARE QUICKHEAL voic EMAIL CUSTOMER using ph QUICKHEAL CUSTOMER to CARE or change it quickly, if you have any of them so contact to get well QUICKHEAL care form us. QUICKHEAL CUSTOMER CARE not working QUICKHEAL CUSTOMER CARE phone number QUICKHEAL CUSTOMER CARE contact number QUICKHEAL CUSTOMER CARE help QUICKHEAL CUSTOMER CARE care QUICKHEAL CUSTOMER CARE wont work QUICKHEAL CUSTOMER CARE wont work QUICKHEAL CUSTOMER CARE link QUICKHEAL CUSTOMER CARE issues QUICKHEAL CUSTOMER CARE usa QUICKHEAL CUSTOMER CARE customer service. QUICKHEAL EMAIL account CUSTOMER CARE ' free QUICKHEAL EMAIL CUSTOMER CARE ' cannot CARE QUICKHEAL EMAIL CUSTOMER ' QUICKHEAL EMAIL CUSTOMER CARE ' QUICKHEAL EMAIL CUSTOMER CARE download ' QUICKHEAL EMAIL CUSTOMER CARE software ' free QUICKHEAL EMAIL CUSTOMER CARE. QUICKHEAL EMAIL CUSTOMER change, QUICKHEAL EMAIL hacked CUSTOMER changed, QUICKHEAL EMAIL hacked can't change CUSTOMER, change QUICKHEAL EMAIL CUSTOMER on iphone, change QUICKHEAL EMAIL CUSTOMER on ipad, change MICROSOFT QUICKHEALe mail CUSTOMER on android, QUICKHEAL EMAIL account hacked can't change CUSTOMER, how to change QUICKHEAL EMAIL CUSTOMER on droid, QUICKHEAL EMAIL CUSTOMER problems, QUICKHEAL EMAIL CUSTOMER not working, QUICKHEAL EMAIL account CUSTOMER CARE. QUICKHEAL CUSTOMER CARE phonenumber. VIKKI
FSECURE +1800246-7609 CUSTOMER Care PhOnE NuMbEr VK VK Get easy steps to forgot or change FSECURE CUSTOMER CARE CARE via phone number#1-800 246 7609 just follow some steps to recover FSECURE CUSTOMER while you want. In varoius conditions many people lost their account CUSTOMER and much more secure information or information may be hacked by anyone so in that case people want to configure FSECURE with FSECURE or other microsoft account services. Their are man one number in easy mode wih simple procedure. Hence search engine suggest many combinations to CARE y certified FSECUREr to suggest people that how to change or CARE FSECURE voic EMAIL CUSTOMER using ph FSECURE CUSTOMER to CARE or change it quickly, if you have any of them so contact to get well FSECURE care form us. FSECURE CUSTOMER CARE not working FSECURE CUSTOMER CARE phone number FSECURE CUSTOMER CARE contact number FSECURE CUSTOMER CARE help FSECURE CUSTOMER CARE care FSECURE CUSTOMER CARE wont work FSECURE CUSTOMER CARE wont work FSECURE CUSTOMER CARE link FSECURE CUSTOMER CARE issues FSECURE CUSTOMER CARE usa FSECURE CUSTOMER CARE customer service. FSECURE EMAIL account CUSTOMER CARE ' free FSECURE EMAIL CUSTOMER CARE ' cannot CARE FSECURE EMAIL CUSTOMER ' FSECURE EMAIL CUSTOMER CARE ' FSECURE EMAIL CUSTOMER CARE download ' FSECURE EMAIL CUSTOMER CARE software ' free FSECURE EMAIL CUSTOMER CARE. FSECURE EMAIL CUSTOMER change, FSECURE EMAIL hacked CUSTOMER changed, FSECURE EMAIL hacked can't change CUSTOMER, change FSECURE EMAIL CUSTOMER on iphone, change FSECURE EMAIL CUSTOMER on ipad, change MICROSOFT FSECUREe mail CUSTOMER on android, FSECURE EMAIL account hacked can't change CUSTOMER, how to change FSECURE EMAIL CUSTOMER on droid, FSECURE EMAIL CUSTOMER problems, FSECURE EMAIL CUSTOMER not working, FSECURE EMAIL account CUSTOMER CARE. FSECURE CUSTOMER CARE phonenumber. VIKKI
Computers & Internet Logo
1,497 people viewed this question
Alun Cox
