How to locate and clean the lint trap
Cannot locate the lint trap on machine. Lint is always on clothes.
  • Anonymous Nov 04, 2007
    I have a kenmore 80 series and I also have a problem with lint or some sort of white residue on the clothes
    Problem Solver:
  • 6 Answers
Top load washing machines do have lint filters, they used older models have trays that sit on top of the agitator. Newer ones aren't as obvious and are attached to the bottom of the inner tub. If you remove the agitator, you'll see a bunch of holes in the bottom of the tub, the filter right behind these holes. Cleaning/replacing it involves removing the inner tub, so it's not an easy task. It is likely that by the time you're having problems with the filter, it will be beyond cleaning and will need to be replaced. Considering all the trouble it takes to get to, you might as well.
Posted on Sep 19, 2009
  • Michelle Lemon Jul 05, 2013
    thanks for the insight.
  • 447 Answers
Most modern machines have no lint filter Dont forget to rate my solution as solved if i answered you question accurately....Thanks!!!
Posted on Oct 01, 2007
  • joey  shearer
    joey shearer Oct 01, 2007
    ok well you keep lookin for that lint filter than
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
Clothes are collecting a lot of lint when washing. Is there a lint filter? I have already tried running vinegar through a cycle.
not knowing the make and model,, I can offer you this ,, if your machine actually has a lint trap it will be located right before the pump under the machine, also,, try using a little more detergent, this helps cut down on the lint left in the machine and on clothes, if you reply to this feed i will try and locate your machine and check on the filter
Jul 24, 2011 | Washing Machines
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
How do I removethe lint? Clothes are coming out with fluff...
Sorry for the obvious.....
Fluff on the cloths is from the lint trap not capturing it from the air flow.
Air is passed into the clothes from the laundry room. It is heated and then passed over the clothes... then filtered air is forwarded to the outside exhaust.
If you are seeing lint on your clothes, then the air coming in from your laundry area is not lint free.
1. check the back/bottom of the dryer for lint accumulation.
2. Remove the lint trap and clean out the duct work.
3. Inspect all the flooring and areas around the dryer for dust/lint - and clean any that you find.
I believe that you will then have a clean and dry load.
The proceedure of cleaning described above should be repeated every 6 months or so....
-Jim
Nov 05, 2009 | Roper RAX4232KQ Top Load Washer
Lint problem
You must GRARANTEE full and free ari flow outside of the building. Typically this type of complaint is related to restricted air flow outside of the machine...normally there is lots of lint, and it exits through the filter, but when flow is restricted, lint remains inside.
Sep 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
My calypso machine leave alot of lint on clothing
you have to clean the lint trap before every use. I assume that you know that. also , you need to clean the area where the lint trap is really good, so you dont have a dryer fire.
Aug 25, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
Why does my washing machine leave lint on my clothes? does this type of washer have a lint catcher?
Most washers don't have lint traps, the dryers are expected to. In your type of top loader some simple traps would be located in the top cap of the agitator. They should be cleaned each load, but they only stop the bigger pieces.
Jul 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
1,919 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
