Question about Kenmore Deluxe KSR400 Iron
Burning odor Thought odor was from plate itself...so cleaned it off, but found that when I replugged it in the ordor was coming from between the plate and plastic...smells just like hot wires.
  • 1 more comment
  • juanstar Sep 13, 2008
    When I plug it in smoke comes out between the plates.Is Kenmore Irons guaranteed for life like Craftsman tools? How do I take it back? I think it is two years old.
  • justansa Jan 15, 2009
    I noticed a smell coming from the iron and its not the plate because there is nothing on it....I did clean it anyway...but I tried dumping the water and replacing it with fresh water and it still stinks. I dont now why or what smells....help
  • ascheuneman Jan 22, 2009
    My was doing the same thing a few days ago, and now it won't heat up at all. It turns on, but doesn't get hot.
REPLACE POWER CORD ITS MOST LIKELY WORN BY THE HANDLE WHERE THE RUBBER BOOT IS
Posted on Aug 10, 2008
Cleaning Carezza soleplate of iron
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Jul 06, 2010 | Philips GC 8220 Iron
How to cean bottom plate with spray starch on it
Rowenta has a cleaning kit found where the irons are displayed.
Faultless Hot Iron Cleaner can be found in the laundry area.
Dritz Iron-Off is with sewing notions.
You can also use a damp cloth dipped in baking soda, but the above listed cleaners will work faster and better.
Apr 08, 2010 | Rowenta Effective DX1900 Iron with Auto...
I need to use the self clean on my Rowenta professional iron
On the Rowenta DX8750 Professional model you fill the water tank, set on high, and HOLD the steam level lever all the way over to the right (where it says "self clean"). I did not see the info on the internet anywhere (not even in an online manual I found - my husband pointed it out to me.
You have to hold the lever over the entire time, it won't stay in that position so you almost have to use two hands. Pick the iron up hold it as you would ironing and rock it back and forth bottom to top. It's good to have a cloth under the iron so the yucky stuff doesn't get on your ironing board. I rocked it, and then would lift it nearly vertical and flakes of yuck would come out in the steam, and browinish yucky stuff would come out of the steam holes - just clean that off the sole plate when cool.
Feb 14, 2010 | Rowenta Irons
Need to clean the plate
Limescale remover, like CLR or Limeaway, or whatever they sell at the hardware store.
Sep 15, 2009 | Euro-Pro Shark Rapido Electronic Iron -...
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Kenmore Deluxe KSR400 Iron Logo
234 people viewed this question
Top Kenmore Irons Experts
Steve
ray gallant
Tom Chichester
Are you a Kenmore Iron Expert? Answer questions, earn points and help others
