Question about Akai PT4298HD Rear Projection Television
Self focus when ever i self focus it goes worse when it's done but it perfect when focusing. My question is that is there a way i can mannual focus or sumthing
    Scholar:
  • 27 Answers
Go into the menu, then go down to "Function", then go to "Convergence". You can then go to the "Red" or "Blue" option and adjust each seperately. This will have to be done with your remote control. Just follow the on-screen instructions.....
Hope this helps you out!
Posted on Oct 21, 2007
SOURCE:
Makes weird noise while auto-focusing
The 18-135 lens focus system is driven by a motor in the lens itself. So there are moving parts inside it, not really gears and pinions and such, but similar. If it works fine and doesn't make the focus jumpy or stick anywhere, it's probably safe to wait a bit and see if it either goes away or gets worse. If it gets worse or the focus jumps, you just need to take the lens in and have it serviced. The mechanism could be out of alignment or need other adjustment.
Jan 09, 2010 | Nikon D80 Digital Camera with 18-135mm...
Unable to focus
I have the same problem and I had the same self diagnosis. Have you had any success? [email protected]
Aug 14, 2009 | JVC Everio GZ-MG130 Camcorder
Red will not focus but blue will ...perfect focus stops in middle
REPLACE THE 2 CONVERGE I.C.'S. PLEASE LET ME KNOW IF FIXED. THANKS.
Mar 15, 2009 | Samsung HCN4727W 47" Rear Projection...
Samsung hdtv1080i saying check factory data self focus nt wkg
Hope this link helps mate,
http://www.howtomendit.com/answers.php?id=79076
Darren
Dec 31, 2008 | Samsung HCN436W 43" Rear Projection...
Squeaky brakes on Ford Focus Zetec
go to local ford garage
trust x
best thing to do
Jul 31, 2008 | 2001 Ford Focus
Rumble noise from wheels
i sugest getting some guidence to throw the bearing on if you over tighten it or not enough there goes your good hard work and double cheak with some one who knows what there doing to make sure its the bearing it could even be somthing in your brake rubbing or your tires humming couse u hit a curb or sumthing.
Its a front wheel drive so u have to take the tire off then the caliber, disc. then with an impact gun take axle nut off diconect the tie rod being held on by one nut then u need a hammer to hit it off set it aside. bottom ball joint is going to have to slip off and your lower control arm will just hang there by this time u and disconnect the axle from the hub fallowed by the two nutz n boolts on the shockn struts per order your self a new spindle. used cols like $80-180 depends on where
Jul 30, 2008 | 2001 Ford Focus
Check Factory Data after fixing convergence and resistors
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
May 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung model HCN4727W
I had the same problem with mine until I figured out it was from the auto self focus. Normally it should be done with a picture that remains constant or close to it, or else the focus gets screwed up. Go to menu and setup, then turn the self focus off. If you look on the remote and slide the lower portion down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button and then press the self focus button and wait until its finished.
Jan 21, 2008 | Samsung HC-P4752W 47" Rear Projection...
Blue blurry on perfect focus
Did you try the manual lense focus in the back? There is a wing nut on it and it's pretty easy to change. You just need someone to look at the TV and tell you when it looks good. Additionally for the Blue tube, it's on the far left. You take off the bottom panel in the back to get to this area. Good Luck.
Jan 13, 2008 | Samsung PCN5425R 54" Rear Projection...
"check factor data" using self focus
Hi.
Not at all familiar with your tv but this sort of message comes up if you have altered eeprom settings while in engineers mode.
To put it right you will need the work shop manual to know how to reset the settings.
Maybe A tech on these forums can help you out.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Akai PT4799HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
64 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
