Question about Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox not cooling
Box does not cool and runs continuously.
  • Anonymous Mar 14, 2014
    Maytag Skybox will not cool
  • 363 Answers
Sounds like the refrigerant gas has leaked out. Any reputable refrigeration engineer can fix this.
Posted on Sep 30, 2007
3 Suggested Answers
SOURCE:
  • 290 Answers
SOURCE: maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Posted on Oct 10, 2007
eagle338
  • 4889 Answers
SOURCE: maytag skybox stopped cooling
The relay on your box is damaged.. You have to get it replaced.. Not to be tried by a novice but if you have some experience in electronics it can be fixed by you. The relay costs around 75$. Good luck!
Posted on Mar 26, 2008
Why did my unit stop cooling beverages?
my skybox run but my beverages is not getting cold,can you tell me what i need to do,or where i can i take it to get fix?
Nov 15, 2012 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox stopped cooling Skybox stopped cooling. Sounds like the relay will kick on briefly and then click off. Everything else works. I took the back panel off and could hear the relay clicking on...
Mar 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
The skybox doesn't cool anymore
How old is the unit,the sealed system may still be under warranty.Call Maytag first.
Aug 31, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox not cooling
sounds like compressor relay --- if the fan and compressor come on and then shut off after about 5-10 seconds -- its the relay --- sometimes you have to also replace the transformer and capacitor on the opposite side of the unit --- all items are accesible from the back of the unit
Jan 23, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox by Maytag not cooling
our skybox just stopped cooling. i think the compressor kicks on but wont cool. can somebody please help me! thanks barbie
Jul 01, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
881 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Bailey's...
Bailey's...
Steve Allison
Steve Allison
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
