Question about Kitchen Ranges
Converting Kenmore gas range to LP???
I've replaced the cooktop burner spuds, flipped over the regulator plug, but there are NO adjustable spuds...just fixed for the oven burner or the broiler burner. The conversion kit that came with the stove only had the 4 cooktop spuds. Am I missing something? It's a Kenmore model #790.78531602 Any ideas? Thanks.
  • 6 more comments
  • jimmy j Sep 30, 2007
    The nipples that inject the gas into the oven/broiler burners.
  • Anonymous Dec 25, 2007
    I have converted the top burners with no problem , incl. the regulator. The broil burner works well but the oven burner ( bottom one) does not get a steady blue flame no matter how I adjust the air flutter. Am I missing a step somewhere.
  • Nevrstop Dec 25, 2007
    I have converted the top burners with no problem. The broil top burner works well. The bottom oven burner does not get a steady blue flame, it also smells real strong of propane.(excessive). Am I missing a step or is there an adjustment besides for adjusting the air flutter.
  • sjDIY Feb 02, 2008
    I purchased Elite model 790.36723600, and attempted conversion. Kit included new orifices only. First step of directions show how to modify the regulator. Problem is picture of regulator doesn't match actual part. From what I see there is no nylon gas indicator to switch around. Label on regulator show meter settings for NG and LP. Makes me wonder if this part is a new design that accepts NG or LP with out modification. Also, turned out spuds to LP settings. Sears was no help. Their installer wouldn't know what to do. I was told by 800-4myhome that I need to contact my LP provider, and have them do the conversion. At this point, I'm surfing the web for anything on the regulator design. Unable to contact LP provider, because it's the weekend.
  • Anonymous Feb 21, 2008
    fgf366esc
  • acdoc Mar 30, 2008
    converted top burners with the new orifices,ove flipped, and still no safe operation of oven
  • GLewisak Apr 09, 2008
    I converted a new range, 790 model to LP. The conversion kit came with the orfices for the range top burners which I replaced, I flipped the regulator as instructed, screwed down the spuds to the broiler and oven. Opened the air to the oven burner as well as the broiler.
    The range top burners work well.
    PROBLEM: The broiler and oven flames can not be adjusted properly with air to eliminate the yellow flame and produce only a blue flame. Should the orfices to the oven and broiler be replaced?
  • Anonymous Feb 27, 2009
    Pressure regulator is not the one pictured
    does it need a new regulator to convert it to LP Kenmore Elite ****
  • 4 Answers
I just converted mine and the regulator plug was not the same as the one in the manual. It had a black plastic piece snapped into the cap that had to be turned over for LP. I unsnapped it and turned it over. I changed the nipples for the burners and they worked great. The oven orifice had to be turned all the way down (clockwise) ans the air damper opened.
When I did all this the oven still had a large yellow and blue flame. I raised the oven orifice up 2 turns and then turned it down all the way and the oven flame was perfect! The oven orifice is hard to turn so make sure that you turn it all the way down using a 1/2 inch wrench.
Posted on Dec 07, 2010
I had success with the conversion. The directions are very cryptic, but it can be done, without the professional emptying your wallet, for 5 minutes worth of work. No adjustments needed on the air shutters, once they are wide open. The orifices are the pain-in-the-a$$es. You need some small tools to get to them, or chance dropping them under the top....which wasn't fun. Oh...and watch which orifice goes where...there are 3 sizes. So, short version, change orifices, open shutters, and flip regulator setting from NG to LG. Orifices take the longest time. ~ sjDIY
Posted on Oct 31, 2008
I have a sears kenmore gas range. When I turn the oven on it gives me an alarm that reads f10 what does that mean and how do I correct the problem?
Posted on Mar 08, 2008
  • 92 Answers
No if you need to make adj. to the bake and broil there are air shutters the tips of the flame should be orange
Posted on Oct 31, 2007
  • 363 Answers
What are 'spuds'?
Posted on Sep 30, 2007
  • bluesy Aug 04, 2012
    "Spuds " are "orifices" also "jets" , the little brass inserts that have smaller holes for propane.
Call your gas company before you cause yourself a carbon monoxide problem or catch something on fire,that is why guys like myself had to get licensed to do conversions so it is done properly
I have a Jenn Air Gas Range Model # JDS9865BDP that is set up for LP gas. What other adjustments are needed other than replacing the burner orifices / spuds and converting the pressure reg to Nat gas?
You will need a new data plate from the manufacturer. This should come with a conversion kit that wil contain everything you need to do the changeover
Jan 08, 2018 | Jenn Air Kitchen Ranges
Why is it no matter which way I adjust the oven's spud orifice, the burner flame stays large, yellow and sooty even after adjusting the air shutter?
Possible problem with the gas regulator allowing too much gas through the system. On LP systems the regulator should be on the storage tank. The regulator on the range usually has a changeable cap and plunger. One direction is for LP and the other direction is NAT gas. In the LP position, the plunger actually holds the range regulator wide open letting the one on the storage tank do the job.
May 02, 2015 | Kitchen Ranges
HOW TO CONVERT FROM NATURAL GAS T PROPANE
Their are 2 types of ranges. Ones with sealed burners and ones that do not have sealed burners. The sealed burner ranges must have a kit to replace the orifices. The none seal burner models are simply called crank down and flip models. That means you flip the screw on top of the regulator to where it reads LP. and then you tighten down the spuds on the top burners and the oven valve and then you adjust the air shutters.
Note: Some stoves with sealed burners cannot be converted to LP. The model number you posted is not a correct model number.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 19, 2010 | Kenmore 72002 / 72004 Kitchen Range
Brown TM210-4 kitchen range... how do i switch from LP Gas to Nat. Gas on this model? Is it just a regulator adjustment? or do i have to change the orifices as well?
Both. If this is a sealed top range, then you will have to change out the orifices and flip the cap on the regulator. If this is an open top style range (the top lifts up around the burners) then the orifices need to be adjusted and the regulator cap flipped. The oven/broiler orifices will also need to be changed or adjusted, depending on which kind they have. Some older models also require converting the oven thermostat from LP to natural gas (and vice versa) by turning the screw to the correct marked setting. If you have your owner's manual, it explains the conversion in it. If not we may be able to find it online for you to download. Douglas
Oct 09, 2010 | Brown Stove Works TM210 Gas Kitchen Range
I just bought a newer "Kenmore" Gas range. my probem is it is set up for natural gas and i use LP gas. Well it came with the LP gas conversion kit. I followed the directions carefully and the range-top...
Remember this: Crank down and flip. You must tighten down all the top and the oven valve orifices and open all the hutters and flip the nut on the regulator. crank down and flip.
Jan 14, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Gas cooktop flames are too high
are you natural gas or lp
and is your range set correctly
is your flame blue
or orange
Sep 15, 2009 | Kenmore Kitchen Ranges
Converting from lp gas to natural gas
just the orifices will do, the bake and broilerahve an adjustable hood thatwill need to be tightened down as well as an adjustment made to the regulator(needs brass nut flipped from nat. to lp.)
Mar 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Convert from natural gas to propane
Step 6:
To prepare the new unit for LP gas you need to adjust several items. First you will need to replace the range orifices or spuds. These are individually sized with marks and colors.
remove_spud-s.jpg Step 7:
Using a nut driver, loosen the old spud and replace with the new one.The trick to keeping from dropping the spud down inside the range is to use a small piece of aluminum foil between the driver and the spud. This should provide enough "grip".
If you do drop one down inside, you'll need torx wrenches to disassemble the burner units and get inside.
orafice_setting-s.jpg Step 8:
tighten_orifica_on_broiler-s.jpgThe oven orifices need to be adjusted. Using an open-end wrench, tighten down the brass fitting on the oven burner valve.
Step 9:
There may be two orifices, one for the broiler and one for the main oven burner.
reverse_for_lp.2.jpg Step 10:
You will need to reverse the plastic pin in the regulator underneath the range. Remove the hex nut and flip the plastic pin and reassemble the nut.
Do not over tighten!
The last step is to open the air shutters on each burner as per directions included with the range conversion kit.
Nov 07, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
7,566 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
