Question about E-Machines eMachines Desktop PC
Need boot load for emachine T2484
I had an electrical black out and now my computer is booting up to my old drive instead of the new I installed. I need the boot interupt to reset the master drive.
  • DBALL Oct 02, 2007
    Thank's I did get into the CMOS/BIOS however it did show the new HD as the first boot device. I have given up and taken it in for repairs, and I hope the HD isn't toast.
    Brigadier General:
  • 6,966 Answers
Hi, You need to enter your CMOS/BIOS setup and set your "First Boot Device". Immediately after powering up, press the "Del" key, display will show CMOS/BIOS settings. Verify that all your hard disks are being detected/recognized by your PC. Thereafter, set your First boot device to your new HD. Save and Exit. Hope this be of some idea/help. Post back how things are or should you need additional information. Good luck and kind regards.
Posted on Oct 01, 2007
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
Jan 17, 2013 | eMachines eMD620-5133 Notebook
I own a emachine w3622 and changed the hard drive. The computer reconizes the new hard drive but when I go to use the operating system disk that came with my computer says disk boot failure. Not only that...
The disk that came with your system is a recovery disk only. You will need a full installation disk from your local retailer or you can match the OS from your old HDD and use the serial key on the side/back of your machine. If you just wanted more space, install both drives and set the original one as the boot drive. the new drive, if properly installed (refer to your hdd instructions and jumper settings) you will see the second drive under "My Computer" as additional storage
May 09, 2011 | E-Machines eMachines Desktop PC
Windows logon screen flashes for 6 minutes
After the 6 minutes, what happens? Does Windows finally load? Does it power OFF?
Let's assume Windows eventually does load. The problem wouldn't be the monitor, instead look at your boot devices. You "could" have a USB Flash drive installed on your computer and that may affect the boot process. Try removing any external USB drives from your computer and try booting again. If it does load quicker, you have to check the internal configuration / setup screens on your computer. There is a boot sequence or boot order sequence that needs to be altered.
Mar 09, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
Windows xp will not install
If you don't see the message on start up "Press any key to boot from cd" Then you need to change the boot order.
Start the PC and hit delete a number of times. This will take you into the bios screen. (Set up screen)
You will have a tab called "Boot Priority" or "Boot order". Make sure that CD/DVD drive has 1st priority. Save & exit & your done. Upon restart if you have a disc in the drive you will get the option to press any key to boot from CD/DVD. By default, most motherboards are set to boot from floppy & then Hard drive so in most cases you will need to enter setup & change the boot order.
Don't forget to rate me.
Oct 19, 2009 | Microsoft Windows XP Home Edition
Computer crashed. Computer specialist restored drive. now cannot boot windows. Used restore disk. Did not work. computer boots dos screen then shuts down. boots again then shuts down.
Sounds like a Windows issue. Depending on how valuable it is to you to get your data off the drive, I would suggest buying a new hard drive (they are fairly cheap these days), installing Windows on that. Word of advice: Remove your old drive when doing the Windows install, so as not to accidentally select the hard drive your data is on. Once you have Windows installed, shut down your computer, remove the power cord, and install your old drive on a separate IDE channel or SATA connection. If your PC still tries to boot to the old drive, change the boot order in your PC's BIOS.
Aug 10, 2009 | E-Machines eMachines Desktop PC
Hard drive doesn't work
You cannot just throw a hard drive from one computer into another there are specific programs that perform specific jobs for individual components that are different in all computers.
May 08, 2017 | Seagate U Series X 20 GB Hard Drive
Installation windows xp emachine t5082
You must find "eMachine" XP USB drivers for your computer.
If all USB support is "enabled" in BIOS, the conflict is with drivers.
XP is loaded with many generic drivers, however eMachines is proprietary and requires eMachine drivers for most on-board hardware.
Contact eMachines support to locate the drivers (if available).
Thanks for using FixYa - a FixYa rating is appreciated!
Dec 14, 2008 | E-Machines T5082 PC Desktop
My pc was doing this but now it's doing something different but simular
Try telling it to boot the CD instead of the disk for now, since you need to install from that...or perhaps a newer OS.
Jun 23, 2008 | E-Machines eMachines T3830 PC Desktop
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
Emachine T2484 will not power up
Try to start it without any memory in it (RAM), if it beeps then you have bad RAM. If you have more than 1 piece of RAM then try one at a time and see if it will boot. If it doesn't beep and still doesn't turn on your CPU is probably the culprit since you have a new motherboard and power supply. I would also try unplugging everything that is unnecessary like the CD-ROM, Hard drive, sound card, etc..
Jan 11, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
207 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
