SOURCE: condenser fan wont come on nor will compressor I do have fan op
Thanks for your Question,
First thing to check is the breaker in the panel to see if its tripped, I would suggest turning to off, then back to on, if it trips right after you have a short, if not you will need to check your fuses at the disconnect, first, shut the breaker off to the condensor, then pull the fuses and Ohm check them, if you have no reading then one or both is bad, I would recommend replacing them both if thats the case, if they check good, then you have bigger issues with your heat pump, if these suggestions do not work let me know and I can go into more indepth proceedures with you on what to do, thanks again,
mr.grzz
