Apple MC062LL/A 16GB iPod nano 5th Gen - Black Logo
C
Christopher Powell Posted on Oct 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I delete all the information on my ipod?
Wesley Billingsly
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Apple Expert 100 Answers
  • Posted on Mar 29, 2014
Wesley Billingsly
Apple Expert
Level 2:
New Friend:
Greenhorn:
Answers
100
Questions
0
Helped
4066
Points
102
Plug into computer and restore the device in itunes.
How to delete playlist
There are 3 ways you can resort to delete playlist from iPhone. Just follow one of them.
If you are annoyed by using iTunes to manage music in your iPod, you may not want to use it to delete playlist from iPod either. Fortunately, besides iTunes, you can use the third-party iPod transfer software to finish the task. Leawo iTransfer is regarded as the best one among all the iPod transfer programs available in the market.
Step 1. Run Leawo iTransfer and connect iPod to computer with USB cable. The software will recognize your iPod and display your iPod information on the main interface.
Step 2. Click the name of iPod in the left sidebar. Then you could see 2 categories: LIBRARY and PLAYLIST. Open "Playlists" tab. All available playlists on your iPod would show up. When you select one playlist, the songs in this playlist will show up in the right part.
Step 3. Right-click the name of the playlist you want to delete, and choose "Delete Playlist" button. Leawo iTransfer would immediately help you remove the selected playlist on your iPod device. The songs in this playlist won't be deleted, so don't worry about that.
When Leawo iTransfer finishes deleting playlist from iPod, users can enjoy the songs in iPod without switching playlists. With Leawo iTransfer, you won't lose any songs of the playlists deleted. So even if you delete all playlists from your iPod device within Leawo iTransfer, you can still enjoy the songs with iPod, or in a much easier way.
Note:
1. Leawo iTransfer supports all iPod models, including: iPod touch, iPod Shuffle, iPod Nano, iPod Mini, iPod Classic.
2. Excepting deleting playlist from iPod, it also helps with other data transfers of iOS devices, for example, you can transfer music from iPhone to computer with this software.
For more methods, check: 3 Ways to Delete Playlist from iPod
3helpful
5answers
How do i delete songs of my i pod
The first way is uncheck the songs you want to delete on iTunes and then sync iTunes with ipod again, then the songs you want to delete will lose from iPod.
The second way is use leawo iTransfer to delete songs from iPod, the way is connect iPod to leawo iTransfer, then right click on the music you want to delete from iPod on leawo iTransfer to choose "Delete", then the music will be deleted soon. However, this tool can only work on Windows computer.
I added songs to my ipod shffle nd now i cant delete them?
To delete songs on your iPod you can connect the ipod to your computer via USB.
This should launch iTunes.
Your iPod should display on the left side of iTunes. Click on your iPod and it will display the contents. Select all of the songs and hit the delete key on your keyboard.
If you do not use iTunes, or this does not work for you, please provide more information.
Thanks!
I want remove songs from my ipod touch 8g but the manual did not say
The following describes how to delete data from your iPod touch. With the iPod touch connected to your computer, select it in the iTunes sidebar, then click its disclosure triangle to show the contents. Select a content area, such as Music or Movies, then select the items you want to remove. Once the item is selected press the Delete key on the keyboard. Remember removing items from the iPod doesn't delete it from your iTunes library.
I hope that information above has helped is some way.
2helpful
How do I delete content
The following information has been pulled directly form the iPod Touch manual.
Remove items from iPod touch: With iPod touch connected to your computer, select iPod touch in the iTunes sidebar, and click its disclosure triangle to show contents. Select a content area, such as Music or Movies, then select the items you want to delete and press the Delete key on the keyboard.
Removing an item from iPod touch doesn’t delete it from your iTunes library.
You can find the manual located at the following URL. I found the information you requested in chapter 4.
http://manuals.info.apple.com/en_US/iPod_touch_iOS4_User_Guide.pdf
If possible please rate this solution.
2helpful
2answers
I forgot the password to my ipod touch
There is only one way, you must restore the ipod which wipes out everything if you forgot it.
Updating and Restoring iPod touch Software
You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch.
• If you update, the iPod touch software is updated. Your downloaded applications, settings, and data aren’t affected.
Note: In some cases, an update may also include restoring iPod touch.
• If you restore, the latest version of iPod touch software is reinstalled, settings are restored to their defaults, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. If you’ve backed up iPod touch with iTunes on your computer, you can restore data from the backup at the end of the restore process.
Deleted data is no longer accessible via the iPod touch user interface, but isn’t erased from your iPod touch. For information about erasing all content and settings, see “Resetting iPod touch” on page 122.
Update or restore iPod touch:
1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2 Connect iPod touch to your computer.
3 Select iPod touch in the iTunes sidebar and click the Summary tab.
4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available.
5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
For more information about updating and restoring iPod touch software, go
1helpful
Delete all songs
Automatically adding and removing songs and playlistsWhen iPod is set to automatically sync all music with iTunes (default setting), songs and playlists that are added or deleted from your iTunes Library will also be added or deleted from your iPod when the iPod is connected and synced with iTunes. If your iPod is set to only sync certain playlists automatically, songs are added or removed from the iPod when they are added or removed from the playlists in iTunes that are synced to iPod1. For more information about automatic syncing with iPod, see the iPod Tutorials and this article.
source: http://support.apple.com/kb/HT1855
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
2answers
My ipod touch is locked and i forgot the passcode and its disabled and i cant link it up to itunes unless i unlock it which i cant
Updating and Restoring iPod touch Software You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch. ââ If you update, the iPod touch software is updated but your downloaded applications, settings, and songs are not affected. ââ If you restore, the latest version of iPod touch software is reinstalled, default settings are restored, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. In iTunes 7.7, you can also restore from a backup without deleting data stored on iPod touch. Note: Deleted data is no longer accessible via the iPod touch user interface, but is not permanently erased from your iPod touch until it is overwritten by new data. For information about permanently erasing all content and settings, see “Resetting iPod touch” on page 94. Update or restore iPod touch: 1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes. 2 Connect iPod touch to your computer. 3 Select iPod touch in the iTunes sidebar and click the Summary tab. 4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available. 5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
2helpful
7answers
Recover deleted music from apple ipod nano blue 8gb
There are several advanced and user-friendly application available for iPod data recovery. Kernel Recovery for iPod tool is one of the effective program, By using this application, you can quick recover deleted or lost files or folder from iPod. Get more details about this software visit http://www.ipodfilerecovery.com/
3answers
Ipod classic
u cant delete anything off ipd without hookin it up to a comp.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
