Question about HP Photosmart 3210 Printer
Error code 0xc18a0406 ink system has failed,
Can not figure out what to do,we can't print copy anything please help..... cheers
  • 2 more comments
  • jorbyn Nov 05, 2007
    thanks but where would i find the ink waste filters?
  • Anonymous Sep 21, 2008
    no sabemos donde encontrar el centro de la impresora ni del problema
  • Anonymous Dec 24, 2008
    0xc18a020a error pops up on my HP Vivera? I just replaced all of the cartridges?
  • Steenhuis Feb 14, 2009
    When chanchin the new cartridges, the inktjetsystem went defect
    Who come?\Can you please assist me with this?
    New Friend:
The OK-cancel-black-color procedure is to be done when turning the printer **OFF** not on.
Then when you turn it back on you'll see "NVRAM RESET" (or something like that) on the display.
It might take a couple of tries.
This is a fix if the problem is not a hardware failure. This same "ink system failure" error also displays if there is a hardware failure and this cannot be corrected with the button/power off technique.
Good luck.
Posted on Feb 10, 2010
Turn the printer off while pressing the following key (it perform a cold reset )
cancle+ok+color+black for 3210
then swich it on
do it twice the your printer is alive .
Posted on Aug 25, 2008
The Ink waste tank filters are usually change by a technician or the counter can be turned back. The ink waste tank is found at the base of the printer
Posted on Nov 05, 2007
I believe your ink waste filters need replacing
SOURCE:
Ink system failure 0xc18a0406..and says to turn printer off and then on and nothing happens and I just put new ink in...all cartridges
The code in your problem might be an error code which if you call HP they will identify what error that states in order for you to fix the problem.
Feb 17, 2010 | HP Photosmart C6180 All-In-One InkJet...
The ink system has failed and can no longer print. Refer to your documentation. ERROR 0xc18a0406
HP support has the following recommendations:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=443024&docname=c01458034#reset_product
Dec 06, 2009 | HP Photosmart 8250 InkJet Printer
My printer says ink system has failed. Refer to
My HP Photosmart c5183
printer says ink system has failed. Refer to printer documentation. Error: 0xc18a0406. Please help.
Sep 24, 2009 | HP Photosmart 3210 Printer
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7280 Ink System Failure
Contact HP for Care at 1-800-585-2494 Toll Free
Oct 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink system failed. unable to print. error: oxc18a0201
Wait two minutes.
Thanks
Aug 01, 2008 | Office Equipment & Supplies
Ink system has failed
Solution
Wait two minutes.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart 3210 Printer Logo
4,875 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
