Question about BenQ FP731 17" LCD Monitor
Blank Screen Now.
I had to leave for work and my monitor started to flash different colors. but at the top left of the screen a message appeared. and to burn off screen. or something along those lines. Does this mean that my Monitor is F.U.B.A.R./Dead? If Not how Do I fix it. Monitor gets power and the green light comes on, but the stay black. Please help.
    Scholar:
  • 116 Answers
Backlight is torched, it happens without warning. These can be repaired, but finding the appropriate backlights, and trying to get this thing apart is a royal pain in the you know what! But your backlight has burned out! Sorry!
Posted on Nov 26, 2007
SOURCE:
Losing TV picture, screen goes blank,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Televison & Video
The TV works but the screen is completely blank. What do I do to fix this?
- Flickering screen
- Dim screen
- Slow start
Feb 11, 2014 | Samsung PN50A400 50 in. HDTV Plasma TV
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Display flashes horizontal lines
It's not unusual for a monitor to use different circuit paths based on the the display resolution chosen and so, one could have a resolution that is faulty, while another works just fine. Monitors normally just get dim, or power supplies fail, or other more common failures, blank or white dots... etc.; but, should a monitor live long enough without failing in those areas, usually one or more resolutions will fail. Doesn't leave you much of an option, other than a repair shop, if one could be found; but, as long as it works at that or another resolution, and I'd check the other settings and use it if you have something where it can be used. Sorry for the not so good news.
Jul 02, 2017 | AOC I2353PH New
Different lines of color appearing at the top of screen
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor (in the same time) that means the video card is ok and the problem could be: the screen of the laptop or the invertor or the cable that attaches the screen to the motherboard. If the problem appears on both screens, external and laptop, most probably the video card/motherboard is defective.
Have it checked/repaired by a professional.
Oct 08, 2009 | Fujitsu Siemens Computers & Internet
SCREEN FLASHES, PINK STRIPES , SOMETIMES BLANKS TO BLACK THEN ON
This issue could be either the Monitor inverter failing or it could be your Video card. If you have another computer available, plug the monitor into a different computer and see if you get the same behavior, if you do, then the monitor is failing and needs to be replaced. If on a different computer it works fine, then you may have a video card failing. Does it seem to happen the longer the monitor is on? Could be as it heats up, it starts to fail.
Mar 03, 2009 | Dell E153FP 15" LCD Monitor
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
Bank screen now.
Problem normally is dry solder of power transistors and inverter transformer.Resolder should solve Intermittent or Display switch-off problems.
Samir
Sep 30, 2007 | BenQ FP731 17" LCD Monitor
Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Sep 11, 2006 | Sony SDM-HS73P 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
238 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
