Question about Linksys (WRT54GC) Router
Linkys router WRT54GS not routing
I've had my linkys wireless router WRT54GS for about 6 months. It just stop working. I replaced it with my old linky wired router and it works fine, so I know I've hooked it up correctly. Unfortunately, I don't have the receipt. I bought it at "Best Buy". Can't figure out what's wrong; I've tried recycling the power by unpluging the unit; I've also tried holding the reset button for up to one minute; no luck. Any ideas?
  • Anonymous Feb 07, 2009
    Same thing happened to me. 6 months and then bam, it stopped routing.
Zerabelle P. (10124): If you don't have the receipt anymore, please call our RMA department at 1-800-546-5797 for more information on your RMA (Return Merchandise Authorization) application.
Posted on Apr 13, 2008
    Brigadier General:
  • 6,966 Answers
Hi, Apparently your WRT54GS is defective. This can be brought about by a power surge or near lightning strike. If after unplugging and/or the hard reset (multiple times) it will not function as before, chances are that it is really dead. And since you have lost your receipt, you will have no supporting documents to request for a replacement. Unfortunately there are no other reasonable option for you but to junk the unit. You are still lucky in a way, normally when routers go bad because of a power surge or near lightning strike, LAN devices attached to it also gets fried. Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Posted on Oct 01, 2007
SOURCE:
Secure my linkys network
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go and your wifi is now secured thanks for choosing www.fixya.com and kindis ly rate this post
Jan 02, 2012 | Linksys 323 Computers & Internet
I misplaced my linkys cd. Is there any other way I can install linkys onto my computer to make in wireless?
The best thing to do is install Tomato or DD-WRT firmware on your router. This will increase your router's potential ten-fold.
Lifehacker did an excellent write up on doing this. Go to: http://lifehacker.com/#!178132/hack-attack-turn-your-60-router-into-a-600-router
Hope that helps!!!
Feb 14, 2011 | Linksys Wireless-G WRT54G Router
How do you reset the password without the disk for a linkys wireless g router
If you cannot access the administrator pages (the setup screen) from a wire connected PC, there is a small reset button on the back of the router. Press the reset button and hold it for at least 30 seconds to reset the router back to the default settings.
Oct 15, 2010 | Linksys Wireless-G WRT54GS Router...
I am installing linskys to my home computer. I follow al of the directions on the linkys cd but when i switch the wire from the modem to the router and plug it back into the tower i wil not have an...
I think you need an extra cat-5 wire.
1.
Plug one CAT-5 LAN cable into the port labeled WAN on Linksys then the other end into the cable Modem where your PC is normally
2.
now take a separate Cat-5 LAN cable adn plug it into port 1 on the linksys - the other end into your PC NIC
3.
Power cycle Cable Modem (remove battery), linksys, PC this will clear the MAC addresses
4.
turn on modem, linksys then pc
5.
loging to windows - open IE on address bar type 192.168.1.1 - this should be the default address of your router (unless you've changed your subnet) in which case I recommend you factory default the route and use default settings. after typing teh 192.1386.1.1 you should see the linksys login
6.
Now try yahoo.com in IE, the routers factory setting for DHCP should work fine without any end user programming from you.
please rate me, good luck
Aug 24, 2010 | Linksys Wireless-G Broadband Router
I have linkys wireless router model wrt54g2v1.after i back up my computer i lost the linkys file. i cannot find cd for installation. now i am unable to open internet.
mpshyla
The reason for the CD is to configure the router to your cable modem. So if you reinstalled your computer you do not need the CD again. All you need to do is set the computer's Gateway back to your router. The links below will help you do this.
http://www.fixya.com/support/r4602477-check_change_computer_ip_address_in
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
Aug 09, 2010 | Linksys WRT54G2 Wireless Router
Everything is connected my laptop was able to find the name of my wireless but was not able to connect. I'm using windows 7 on the laptop. Any idea of what i should do to fix the problem. Everything was...
Hi. First issue why your laptop cant connect to your router is regarding witht the password. Make sure that you are typing in the correct password of your router. Check the type of authentication used e.g WPA, WEP etc. Second issue, is this the first time you used windows 7 OS in connecting to your router. There are issues in linkys routers that is not compatible with windows 7 and you need firmware upgrade for your router. You can also try to test the connectivity using a wired conncetion (LAN cable) conncet directly to your router nd se if you were able to get an internet concetion using a wired connection.
Have a good one!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jul 28, 2010 | Linksys Wireless-G WRT54GS Router...
I need security code # for my wireless linkys router
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Mar 06, 2010 | D-Link Computers & Internet
Will a Linkys wireless G adapter work on a X-box 360 using a N router.
Yes it will work. Because it is Compatible with Wireless-B (802.11b)
and Wireless-G (802.11g) Standards
Nov 19, 2009 | Linksys Compact 2.0 10/100 (USB200M-CA)...
I am trying to install a wireless printer and have a Linksys wireless router. To install the printer I am being asked for the security key on the rouner. How can I find this? Thanks!!!!!
The router must have had security key, first, you can reset the route with the reset botton on the back the router... they the security will be off
Sep 13, 2009 | Linksys Wireless-G Broadband Router
Linkys
hello, Anytime windows gets stuck "aquireing the connection" there is usually a security key thats not entered correctly. Do you know if you configured your wireless network for "wpa" or "wep" ? If so, we need to get that setup on your Laptop.
Jan 09, 2008 | Linksys Wireless-G WRT54GS Router...
Open Questions:
Linksys (WRT54GC) Router Logo
439 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
