Question about Tivo Humax® HUM-T2500Digital Video Recorder with
Tivo hard drive
I can tell the hard drive is dieing on this tivo since it makes alot of loud loading and head clicking noises and sometimes it restarts itself also when i try to record or play things back or watch things with it it freezes in spots i would like to know how to go bout replacing the hd
    Genius:
  • 1,139 Answers
Here is a link to replacing the hard drive in your TiVO. Remember its just like replacing a Computer Hard Drive. I hope this helps: http://tech.yahoo.com/gd/adding-a-new-hard-drive-to-your-tivo/2625
Posted on Oct 01, 2007
SOURCE:
HP Deskjet 3070 B611 series making a loud noise
the harddrive is dying you should backup your data the noise is caused by the head scratching on the platter which is not heathy
Sep 17, 2013 | Computers & Internet
My Western Digital Caviar WD1600BB 160 GB hard drive in my dvd recorder is making a clicking sound, how do I test to see if it is the heads that are faulty or the circuit board?
Welcome to Fixya. If you are hearing a loud ticking or high pitch noise on the hard drive it means that the hard drive will be defective anytime soon. If you can take out the hard drive and backup the files on you computer and replace the hard drive on the computer. Loud noise can be caused by a bad spindle or the hard drive or the hard drive is frying inside the dvd recorder.
If you have questions please let me know. Thanks
Oct 10, 2011 | Western Digital Caviar WD1600BB 160 GB...
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
Plug in cord and just hear clicking noise not connecting to a computer
This means that the WD could is trying to connect to the computer but looses the connection. Try plugging the usb cord in another usb slot on your computer. Or try using another cable. Make sure the WD is not giving out any red led light on the device.
Mar 01, 2011 | Western Digital My Passport Essential...
Drive is nor recognized on my machine Rhythmic buzzing almost sounds like an alarm emanating from drive.
Sounds like the HDD is malfunctioning , with all
spinning hardware a resonant buzzing is common
unless its loud , open the closure make sure that its
secured to the housing and all connection are secured
while its on place a unsharpened pencil on it to your
ear listen for a spinning sound it should be steady
an unsteady spinning sound means the motor is
malfunctioning and ready to die , a clicking sound means the units heads are too ready to die and
sometimes the closures malfunction , if you can remove the unit from its closure and set its jumpers
to slave and hook it up to a PC you can troubleshoot
the closure from there and the unit itself
Jan 28, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
My washer makes a loud clicking noise when stopping the spin cycl
two things to check 1st check the pump for an object in it or the next thing to look at is the motor drive coupler do you see alot of black rubber and whiteish looking pegs if so rep the motor drive coupler you'll need 285753 or 285753a
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I havee had my Seagate Freeagent 500 GB for a yr. Worked great. Just today, it wouldn't load. Not recongnized on either my laptop, Vista or my desktop XP. Hums and clicks. I have over three quarters full...
hard drive has a bad head ... shop around you should be able to find a better price ... best of luck to you otherwise try pulling the harddrive out of the enclosure and putting into a computer
Aug 04, 2008 | Computers & Internet
WHAT DOES THIS NOISE MEAN?
More that likely the drive is dying?? :-( ..
Usually the 'click, click , clicking' noise is the 'actuator' trying to read the drive.. One old trick that workings sometimes is to remove the HardDrive from the enclosure. Put it into several ziplock baggies and put it in the freezer over night (colder the better). quickly remove the drive and put it into a computer. Sometime you can read the drive for about 10-15minutes. But this trick only works about 20% of the time.. The only other option is DriverSavers.com (about $2k -- Yikes!!! ) :-(
Feb 23, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Loud Humming
It's possible a fan or a hard drive is going bad. When the bearings in those devices start to go out they a start making noises like that.
Jul 18, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Televison & Video Logo
178 people viewed this question
Top Tivo Televison & Video Experts
Damen Wong
Damen Wong
ray gallant
ray gallant
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
