Question about LG RU-60SZ30 60" Rear Projection HDTV-Ready Television
I have an LG RU-60SZ30. I had a technician tell me that I need a new lamp ballast assembly. So I finally have replaced the lamp ballast assembly as well as a brand new phillips lamp. And the tv still starts blinking while its warming up and then shuts off when it sounds like its about to turn on. Anybody have advice?
  • Paul Mueller Oct 28, 2013
    the tv operating light starts blinking yellow for awhile and you can hear the tv warming up then the light switches back to red
SOURCE:
SOURCE: how to solve a blue picture in my lg model Ru-60sz30 rear proyection?
Here is in laymans terms what the problem is. The blue film from the RGB on the input is close to a heat source and over time the heat source burns through the filter and washes out the blue lead. I know that was a lousy explanation, but that is what it is. I had mine replaced 2 months ago. Supposed to be a permanent fix. (extra filter put in.) When it is replaced, they replace the complete apparatus, all three colors, light, and mirror.
Posted on Jan 04, 2008
  • 5 Answers
SOURCE: My LG projection tv has bluing on the botttom and
Actually hardrocko it is not a DLP light engine so the link you put up is completely wrong. DLP TVs have light engine and LCD projection have optical blocks. These are two totally different technologies. It is possible to fix this problem by cleaning the blue lcd chip. This link is more efficient in helping you solve your problem. It is for a sony LCD projection but very similiar to the 60in LG. http://sites.google.com/site/sonylcdrptvproblems/optical-block-defects and http://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement these two site should help you fix your problem if these don't fix it then unfortunately you will have to invest in a new optical block which will cost roughly $700. I've got the RU60SZ10 which is pretty much the same TV and these two sites have helped me tremendously.
Posted on Jul 21, 2010
SOURCE: LG LCD Projection TV RU-52SZ30,
It might be sticky to fix this open it up extremely carefully and clean the button hope this helped
Posted on Nov 21, 2010
  • 52 Answers
SOURCE: LG RU-60SZ30 when turning the
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Posted on Dec 04, 2010
cyberfast
  • 155 Answers
SOURCE: I have a tv lg
yes the yellow spots mean its a optical block problem. in your case it is the yellow LCD panel inside the optical block. this is not a diy fix you need special tools to realign the panel. sorry for the bad news.
Posted on Apr 05, 2011
I was told I need a new lamp ballast assembly. I was also told by someone to order 6913V00002C Ballast (EUC 100 P/11) but when I opened my TV and took out the "bad" ballast, its is a EUC 100 C/00. Anybody...
so the one first is an LG model ballast but the one in the tv is a phillips one, strange.. can you give me the bord number power side... it is always best to replace old number so the damaged numer one should be the number you use. LG, Philips etc use different part to make the same tv model. e.g one can be made in twain and the other from china. both the same case do the same things but have completely different parts in side. Looking at the parts on line they don't have the same connections or the same voltage so would be a bad idea to try and put the new one in with the wrong number.
Oct 22, 2013 | LG RU-60SZ30 60" Rear Projection...
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
I have an LG RU-60SZ10 that I just replaced the bulb but now I need to reset the lamp hours How can I?
You need a special servicer remote control, this will allow you to get into the service menus, and reset the hour clock. I have one in the Chicago area, otherwise don't worry about it. The actual operation of the set will not be affected.
Feb 21, 2010 | LG RU-60SZ30 60" Rear Projection...
I have a 60 inch LG t.v. that needs a new bulb
The part number for the lamp is: 6912V00006C
It can be purchased from tritronicsinc.com for $199.00 plus shipping.
Dan
Dec 17, 2009 | LG RU-60SZ30 60" Rear Projection...
NOS GE Ballast - Good?
Hi, The GE ballasts that you are referring to is OK. if stored correctly, they should be just fine.
Feb 25, 2009 | LG RU-60SZ30 60" Rear Projection...
Ballast question
The site I work for has the same manual as you most likely as its the factory service manual. So we dont have the schematic either
May 13, 2008 | LG RU-60SZ30 60" Rear Projection...
Ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
LG RU-60SZ30 60" Rear Projection HDTV-Ready Television Logo
Ekse
