SOURCE: RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
SOURCE: When I push the power button on my RCA HDTV
Sounds like the bulb went out.
Go to http://www.purelandsupply.com/RCA-Projection-TV-Lamp.html and order a new bulb for under $200.
They are easy to intall; a screwdriver and 10 minutes.
SOURCE: I have a 50 inch RCA HDTV scenium model HD50lpw175
TRY THE BLACK LEVEL SETTING AND CONTRAST SETTING
SOURCE: no picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
SOURCE: I have a RCA R52WH74. When you turn it on there's
replace the deflection board. You need the ITC222A deflection board PSB-260 you can get a replacement deflection board from www.tvrepairworld.com which also has the CD that shows how to remove the old board.
