Question about JVC HR-S9500 S-VHS VCR
JVC HR-S9700EK Auto shutdown: The SVHS recoder is fine in standby and will load tapes. However if you try to switch it on it only stays on for 1 second before shutting itself off.
  • davidj Oct 01, 2007
    Thanks for suggestion - but this problem exists even without a tape in the unit. So do you still think this is the casue.
    Basically the unit can be switched on for only 1 second before it switches itself off. tape or no tape.
    Brigadier General:
  • 6,966 Answers
Hi, This is a common problem with some VHS units. The problem is that the tape does not fully extend over the video head and the slack sensor shuts the unit off. This involves the motor and driving mechanism that actuates the spreader arms that moves the tape. Usually this is caused by slippage of a small rubber belt. Though the repair work involve is relatively easy, removing the mechanism and replacing the belt would require that you be familiar with component placement and certain timing sequence of tape loading. Your best bet probably would be to seek the services of a qualified professional. Hope this be of some help/idea. post back how things are or should you need additional information. good luck and kind regards.
Posted on Oct 01, 2007
  • Louie  Role
    Louie Role Oct 02, 2007
    Hi again,
    Based on your updated information -
    The unit switches itself off as a safety feature. The unit senses something is wrong and to prevent further damage switches off. This can either be in the power supply section or any of the mechanical section (including parts in initial post).
    Repair would involve knowledge of electronics circuitry, voltage readings and possibly desoldering/soldering. Further familiarity with mechanical timing/sequencing may also be required.
    Perhaps your best option would be to seek the opinion/services of a qualified on-site professional. You have to determine if the repair is economically reasonable or consider replacing the unit.
    Cheers.
SOURCE:
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
Videorecorder videodrum replaced
I would say that it's because you haven't used the original test tape. Where the recordings that play up done on the model before the problems started? If so then that would prove that the tape is just slightly off. I can't see it being a fake head, nobody would make any money doing fake VHS heads these days!
May 19, 2013 | Televison & Video
TELEVISION IS IN STANDBY WONT SWITCH ON TO PICTURE
First is the set should have a 1 year parts and or labor warranty--second: in order to offer advice or give help I need to know brand and model number.
Dec 06, 2012 | Televison & Video
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
Nov 24, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Can I record from SVHS tapes or only from VHS tapes? Thank you, Victor
To record from SVHS you will need to hook it up by way of cable or SVideo Connecting and red and white RCA plugs. It should work just fine.
Jan 13, 2010 | Panasonic DMR-E85H DVD Recorder
Vcr will not play tapes,it ejects the tape after a few seconds
This may be caused by the mode switch.
By the way it uses a K-Deck Mechanism.
Sep 11, 2009 | Televison & Video
SLOW DOWN PLAYBACK MODE
You cannot play SVHS tapes on a standard VHS machine. Your solution is to either:
1. Buy an SVHS Home unit (not a great idea)
2. Use regular VHSC tapes in your camcorder (these will playback fine in your existing home unit).
3. Hook your camcorder directly into your TV and use the camera as a playback device.
May 02, 2009 | Televison & Video
Incorrect copy protection error on SVHS tapes
I would recommend obtaining a "stabilizer" box just to remove any possible Macrovision. You can usually pick these up in small electronics stores or Ebay. I have heard of this problem with Mini DV tape camera recordings as well.
Mar 20, 2009 | Panasonic PV-4664 VHS VCR
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
I have a HR-J625EA JVC VCR & video cannot be ejected.
this sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Dec 08, 2008 | JVC HR-S9800 S-VHS VCR
JVC HR-S9500 S-VHS VCR Logo
824 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
