Question about Frigidaire GLTF1040A Front Load Washer
Replace drain hose
I am unable to see where the drain hose connects to the machine, It disappears into the back of the washer, How do I make the repair? Will I need to remove the back of the washing machine?
  • 447 Answers
Yes the back panel comes off easily remove the fill hoses and take out the 15 or so screws around the panel, also depending on the age of your machine it may have a front axcess panel that will aid in getting to the drain pump better. Dont forget to rate my solution as solved if i answered you question accurately....Thanks!!!
Posted on Oct 01, 2007
Own a lg wm1832cw front load washer doesnt seem to clean properly when wearing tee shirts for an hour smells like they never were washed paid alot of money for this thing seems cheaper top load machines...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Sep 12, 2011 | LG WM1814CW Front Load Washer
I am having mold and mildew smells, and when I pull back the rubber ring it is full of slim-like dirt. My clothes are now coming out smelling! How do I clean this, what products should I use??
Hi
Daniel
Aug 31, 2011 | LG WM-2277HW Front Load Washer
I have lost manual can you run something thru a load to clean machine such as vinegar or baking soda my machine smells musty
Hi
Daniel
Aug 29, 2011 | Kenmore Front Load Washer
Poor quality wash from miele w2240 and washing smells stagnant. We use a good washing powder and softener. The machine is 7 years old. Should we buy a new one?
Hi
Daniel
Aug 06, 2011 | Miele W2240 Front Load Washer
Hi, there is a really bad smell coming from the machine, also i have just done a 60 cycle and the white wash has come out with black marks on, looks like fungus,
Hi
Daniel
Apr 18, 2011 | Washing Machines
Washer will not drain water frigidaire
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please revert for any further assistance.
Hope this helps...
Daniel
Feb 17, 2011 | Washing Machines
My washer will not drain?
Hi
Hope this helps...
Daniel
Jan 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
My washer will not drain the water is there anyway to manually drain it
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Washing Machines
My washer wont pump water out hose is not blocked
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please back for any further assistance.
Daniel
Nov 26, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Frigidaire GLTF1040A Front Load Washer Logo
1,325 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
