My XBox 360 has recently been unable to play any games. I put a disc in the tray and press the close button, but the tray keeps opening automatically. I tried to close the tray without a disc being inserted and it still happens. The only way I can close it is by holding it closed when turning the console off. I tried this last method once successfully with a game inside, booting up the console again and the game played fine, so I think it's just a fault with the disc tray closing mechanism. It's no longer under warranty. Any ideas on repairing it?
I was experimenting with the xbox a few days ago and turned it on it's side (it used to be kept flat) then opened the disk drive and inserted a disk. When I closed the tray it stayed closed and I could once again play games. How's that for a cheap alternative!I was experimenting with the xbox a few days ago and turned it on it's side (it used to be kept flat) then opened the disk drive and inserted a disk. When I closed the tray it stayed closed and I could once again play games. How's that for a cheap alternative!
You can't post conmments that contain an email address.
I have the same problem i called xbox and they said that it needs a new disk drive and it would be 100.00 so if you want it fixed youll nedd to call 18004myxbox and they will give you all the info on were to send it or for 100.00 more you can buy a new one like i did
Use the following steps to close the disc tray on an original Xbox 360 console. Step 1: Remove the disc from the trayStep 2: Make sure the faceplate is on correctly The faceplate is the plastic piece on the front of your console.
Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3.
Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray. Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing. If your disc drive still will not close, please try step 4.
Step 4: Move the disc drive tray
Gently move the tray up and down, and then from side to side.
Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console.
Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc.
Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3.
Step 3: Move the disc drive tray
Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired.
Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
try putting the game disc into your game console and close the lid with your hand without pressing the close lid button. hold the disc tray with your hand and turn off the game console. Turn on the game console. If problem still persists try cleaning the xbox with a blower or a vaccum. Pm me if problem still continues. Thank you .
Try putting the game in straight. By straight i mean putting the disc in where the xbox 360 logo at the top of the disc goes in the tray towards the xbox360. if that does not work contact microsoft
xbox 360? you open the disc tray by pressing the eject button directly above the tray, insert the disc and then close the disc in the same manner. if the game does not automatically start up then you will be required to go to the row that says My Xbox and the very first tab should say the game you have entered. you play it by pressing A
A lot of people have this problem. Before you post, look around.
Anyway, I was able to call xbox 360 customer support. We did the troubleshooting but it still would not work, so they took my xbox 360 in for repairs. I would not try to fix it on your own because it might negate the warranty.
