One of your usb devices has more than likely has had a driver get corrupted. Try unplugging your devices one by one until you find the culprit. Once identified download and install the latest driver for that device. this should correct your problem. Good luck.
there are drivers needed for this item you may need to download them also re install your usb drivers an attach to a different usb port not thru a hub.
THE PROBLEM MIGHT BE IN THE DEVICE YOU ATTACHED TO YOUR LAPTOP.
IF THE DEVICE IS OK THEN THE PROBLEM IS IN USB PORT OF LAPTOP.
FROM MICROSOFT WEBSITE DOWNLOAD AND INSTALL (DISABLE PREFETCH), HOPE SO THAT IT WILL SOLVE YOUR PROBLEM
Go to Start --> Control Panel --> Printers and Other Hardware --> System --> hardware --> device manager --> right click on the usb port that is malfunctioning (should have a red or yellow exclamation by it), right-click it and click on Update Driver
If that fails, try another USB port on the computer to see if you have more success
