Panasonic KX-TG2382 Cordless Phone Logo
John Peltier Posted on Oct 28, 2013
How do I program call forwarding? - Panasonic KX-TG2382 Cordless Phone
1helpful
Only rings 3 times then transfers to another ext.
Mitel call forwarding is a double-edged sword. It can be controlled by the end user via user-programmed forwarding and it can also be controlled by the system programmer via system call rerouting. User programmed forwarding OVERRIDES system programmed 1st alternate, but does not override the 2nd alternate reroute destination (if 1 is programmed). Try un-forwarding the phone - if still no joy then contact the system support person. Hope this helps. (User-programming commands are initially defined by the system support people when the system is initially installed, so I can't tell you how to do it... you'll need to know what the key commands are (or unforward using the Superkey function if provided).
Canceling call forwarding from one extention to another
On the extension that is forwarding use Feature #4 to cancel the call forwarding unless it is programmed under the capabilities section in programming. This will require someone with programming ability to make the forwarding change back to the voice mail access number.
1helpful
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Cal do you use the call forward feature on the AASTRA Telecom 9316 CW telephone to forward calls to another coworkers telephone number.
In order to set call forwarding on this telephone, must first have the feature CFV (Call Forward Variable) on in the line. This feature can be provided by the telephone service provider.
A typical feature code for this is *72 to activate CFV and *73 to deactivate.
You can program these features on the M9316 telephone by do the following:
CFV activate
1) Press the SAVE key.
2) Then select the key where you want to program the feature.
3) Then enter *72 (optional: plus the telephone number of where you want the call to forward to).
4) Press SAVE twice.
CFV deactivate
2) Then select another key where you want to program the feature.
3) Then enter *73
Be sure and label your buttons.
To use go off hook and press the key you just programmed.
How do i forward my office calls to my cell phone
Go into programming, set #322, and your extension to have permissions for forwarding.
Then, set your cell number as a speed dial at your extension. Feature 00, then feature 80 and enter the number as you would dial it from your extension.
then press a button with lights, and press feature 11xx80. where xx is your extensoin number.
When done, press feature 00 to get out of programming.
To activate, press the button you programmed the forwarding on., then the green light will come on. To un forward, press the button again.
Placing a Forward Button on 1616 IP Phone
What you need to do is, set up a button that will turn forwarding on. then set a number in manager on the forwarding tab, set the number. If the number is going to change a lot, then you should set a second button up as, forward number. One changes or sets the number, and the other toggles forwarding on and off
Forwarding a busy phone
you'll need the programming template that goes over the phone keys if you're not familiar with programming...
feature **admin (use #s on dialpad)
type admin again
select #6 permissions
enter set (ext)# you want to forward
scroll down to "forward on busy" & select
you'll see "forward to" hit the "change" button
enter in the extension # you want it to go to when busy
then select to store
1helpful
How do I divert calls from Console to mobile KX-T7636
Press the Program button. enter 50 for call forwarding and press Enter. enter 2 and the number (ie 25551234) to forward ALL calls to the specified number. enter 3 and the number to forward when busy, 4 and the number to forward when there is no answer, and 5 and the number for when you're either busy or there is no answer. Hit Enter and then the Program button again.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
