Question about JVC AV-32S575 32" TV
HDMI The HDMI input becomes disabled all by itself. Apparantly there is a sensor that senses that the back has been removed from the set. There is a proceedure to re-enable it but it requires me to remove the back of the tv, connect a jumper, plug in the power, unplug the power then put the back on the set. The HDMI input will now work until it stops working without any warning or tampering with the set. Does any information of this problem? It seems like a bug or maybe the sensor is intermittent.
    An expert whose answer gotĀ voted for 100 times.
  • 140 Answers
Prior to disassembly, unplug the power plug from the AC outlet without fail. (Turn the power "off".) Short the SB connector [1] pin and [2] pin of the DIGITAL INPUT MODULE PWB. (At the time of assembling) Before the rear cover is inserted into the cabinet,release the short-circuit between the SB connector [1]pin and [2]pin of the DIGITAL INPUT MODULE PWB. After releasing the short-circuit between the SB connectors, do not turn the power on until the rear cover is inserted into the cabinet. Negligence in carrying out the above steps may cause the inactivation of the TV.
Posted on Oct 02, 2007
No sound on my Kogan 49" smart TV when connected to Foxtel or DVD through HDMI inputs
could you check on tv setting for hdmi that its in digital input and not external input. as sometimes the device settings are wrong, also its best to try a different hdmi cable as sometimes the cable can become damaged.
Jun 30, 2017 | Televison & Video
HDMI cable was removed when TV on standby and X-box off. It was then replaced and we now have a message. "No signal. Check connection" and nothing else. Please can you suggest a fix? Have checked...
Might some how got that HDMI input port shorted?Tries tv unplug and that HDMI cable input it into another HDMI port,replug tv back about an hour later.So the tv resetting itself back to factory setting.Tv on goto tv menu,goto tv PICTURE SETTING going down to do resetting.This should resetting the whole tv Tuner signal board.These steps,should help ur tv HDMI ports functions again.
Jan 21, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
Every time I turn my Yamaha RX-V565 on it switches to the AV1 input instead of staying on the HDMI input that it was on when I turned it off.
Set your TV, Sattellite receiver and audio where you want it when you turn on the set. Then hit the Scene button named "TV" and hold it down till the yamaha receiver says set complete and it will turn on to HDMI 2
Feb 01, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Denon AVR 3806 Philips 42PFL3603D/F7 Compatibile
Make sure the control feature is disabled on both units so that they are not trying to send control signals to each other.
Secondly make sure your input is configured to hdmi for both audio and video within the receivers on screen menu The receiver usually auto senses the digital audio signal but doesn't automaticly know that it should use hdmi for video.
Dec 19, 2009 | Denon AVR-3806 Receiver
I have an HDMI Cable how do I connect my computer to my Plasma TV
Your laptop has to have an HDMI output and the tv has to have an HDMI input. Put the tv on that HDMI source inpput, the laptop will sense the new device and install a driver for it, which is your video driver. Your video driver has to be capable of driving two monitors. The best bet here is to update the video drivers. When it senses the TV, the tv will show what the computer monitor shows and windows will ask you if you want to use the tv as the primary or leave the setting as they are and run both monitors. Whatever you choose, when you power down either the tv or the computer the computer will sense the change and revert back to the default settings.
Sep 27, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
JVC 40 inch LCD digital inputs (1 and 2) no longer works. Standard video and component cable inputs work, but not HDMI. Please help
This TV has a sensor that deactivates the inputs when light is sensed. perform this procedure to correct it:
1. press "Sleep" button on the remote
2. while "Sleep timer 0" is showing, simultanuously press "display" and "video" button on the remote
3. you should be in the Service menu of the TV....if not you should do the steps again
4. select "self check" from the displayed options.
5. when the "self check" menu is displayed, Power off the TV.
6. unplug and replug the TV.
7. Check the digital input.
if the input never worked for you, it is possible that you have the DVD/Bluray/whatever set up incorrectly. I don't think this TV accepts 1080P resolution so make sure it is set to 1080i or lower
Jun 23, 2009 | JVC LT-40X776 40 in. LCD HDTV
Hdmi input on pioneer pdp-r04u doesn't work. The component cables work, but not the HDMI. The digital audio works.
the r04u comes factory with hdmi DISABLED, hook up your hdmi device, and turn r04u to the hdmi  input (input 1 or input 3)  then:
To activate the HDMI terminal:
1 Press HOME MENU.
2 Press /  to select “Option”, and then press
3 Press /  to select “HDMI Input”, and then press
4 Press /  to select “Setting”, and then press
5 Press /  to select “Enable”, and then press
there you go
Sep 04, 2008 | Televison & Video
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
JVC AV-32S575 32" TV Logo
123 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
