Hannspree HANNSflora TV Logo
F
FERGUS Posted on Oct 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connect laptop - Hannspree HANNSflora TV
Strech
Level 3:
  • Master 1,562 Answers
  • Posted on Oct 28, 2013
Strech
Master
Level 3:
Answers
1562
Questions
0
Helped
484770
Points
4382
You need a HDMI cable and connectors.
http://ts3.mm.bing.net/th?id=H.4983236998204530&pid=15.1
Also available are USB to HDMI cables.
My samsung r519 has stopped connecting to the internet
Does the Laptop say it is connected to your wireless router? If not, connect to your router. Maybe the laptop is continuously polling because you keyed the Wireless Network Key/Password in wrong. If it's wrong, it will never connect.
Try disabling the wireless connection, then enable it and see if it connects and lets you out to the internet.
Make sure you are using the same Authentication (None, WEP, WPA, WPA2) as the laptops that you say work.
tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 • Computers & Internet
2answers
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
I have S5350 model mobile, how can i transfer photos from mobile to my laptop?
Try to connect it in bluetooth connection. (Wireless connection.). Or try to connect your phone in USB connection. (Wired connection) For wireless connection:
-open your first your bluetooth connection. (phone and laptop) -send the the files/photos via bluetooth connection. -accept the files from your laptop.
For wired connection: -connect your usb to your phone -set your phone connection to mass storage -connect to your laptop, if your laptop detect your phone, search your files, then copy it.. =)
May 21, 2011 • Cameras
#3 laptops having problems connecting to wireless at random times
check the configuration of your. try and configure it to be AP CLIENT. i think this would solve your problem.
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
1helpful
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Iam trying to connect my laptop to the innet. i have wrt54g router.
Hi jjroyc
Let's see if we can get your laptop connected to the Internet.
First, I have some questions and a few instructions for you.
(01) Is this a new (to you) router?
(02) Do you already have one or more computers connecting successfully to the Internet using this router?
(03) If yes, are any of them connecting wirelessly?
(04) Have you recently (at another location for example) successfully connected this laptop to the Internet? If so, did you connect it "wired" or "wirelessly".
(05) Are you trying to connect your laptop to your router "wirelessly" or "wired"?
(06) If you are trying to connect the laptop wirelessly, turn off your laptop's wireless radio and connect the laptop to the router "wired" instead (using an "Ethernet Patch Cable"). Once we've established that the laptop is capable of connecting to the Internet via the simpler "wired" connection, then we'll move on to the more complex wireless connection.
(07) Please, go HERE to download the manual for your particular router. You will need to determine the version number of the WRT54G model 1st. There are instructions there that will guide you through this.
BJ
Can't connect to laptop
that your router have a Dynamic setting?
Top Hannspree Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
