Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
1993 Sony Trinitron 27"
By broken1 on Sep 30, 2007
Will not turn on. No response at all. No noise, click, lights, nothing. The fuse in the back next to the plug is OK. Doesn't work with remote or manual power switch. Worked one minute and the next...dead (so I'm told). It is as if it were unplugged.
Same Problem
Dec 16, 2007
-   Mine is did the exact same thing two days ago. I also took the back off and looked at the fuse. The fuse is fine. I didn't mess with it anymore after that. I would just like to know if this sounds fixable or would I be better off just buying a new tv.
Thanks, Rosie-   Guest
Dec 15, 2007
-   Same problem on my 94 KV-27TW78...I had a power surge and had an outlet blow and even though the set was on a surge protector it will now not come on as is unplugged. I checked the bus as well and it looks to be in working order. Any suggestions on where I would find a free service manual for this model or advise on how to check the power supply?
Josh in Houston
-   fixithack
Best Solution
posted on Oct 02, 2007
Helpful)
modern
Rank: Wiz
Rating: 80%, 660 votes
as set is dead
the problem is in power supply or horizontal section.
though it is a simple &less time taking.
but if you have no TV repair experience, or any experience tracing circuit flow with a schematic, call in a tech to assist you with this repair. This tv set is not the place to be experiementing inside of. You probably have bad capacitors and transistors in the power supply or the sweep power supply.
Good Luck
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
need four digit code for sanyo tv for the one for all remote
Answer
i cant find the codes for my remote control thomson roc2404 to make the television work the tv is... (More)
Answer
i have a wharfdale lcd2010a tv and cannot get rid of the source menu in the bottom left hand corner... (More)
Answer
can't get my dish network remote to program to work my new APEX 40 TV. The remote codes on the dish... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
