You don't say what else works. Have you tried it with FM to eliminate external source causes? Does your TV get audio passed through to it? That would establish that there is program material to be amplified. Headphones work?
The following is from the User Guide -
Check to make sure that each speaker has been properly connected to the
speaker output jacks on the rear panel of the DCP501. Check that the speakers are working by utilizing the Test Tone function as described in the “Operation” section.
Verify that the DCP501 has not been placed in MUTE mode.
Check that the volume control on the DCP501 has been adjusted to an
appropriate listening volume.
Verify that the DCP501 is set to the correct source (CATV, VCR, DVD, Tape,
etc).
If the front panel displays O V E R L O A D , one of two things has happened:
1 If the DCP501 detects the speakers have a short circuit, it shuts down
the amplifiers. Switch the DCP501 off, remove the short circuit, and turn
the DCP501 back on. The DCP501 should now work as normal. If
O V E R L O A D is still displayed, a short circuit condition remains.
2 If the maximum amplifier output power is exceeded, the DCP501 shuts
down the amplifiers. Turn down the volume a little and switch the
DCP501 off and then switch the DCP501 back on and the DCP501
should now work as normal. If O V E R L O A D is still displayed, turn the
volume down some more.
The Speaker Setup menu has a Speaker Reset (to default settings) option.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Motorola DCP-501 5.1 Channels
Hi all. I have a few Motorola DCP 501s that I purchased and had added to my comcast account. They...
(More)
Hi all. I have a few Motorola DCP 501s that I purchased and had added to my comcast account. They have been great. however, one of them has developed a problem. Intermittently, I began receiving "One Moment Please..." message when trying to use for TV. I've confirmed with 100% certainty that the problem is not with Comcast but with the box. It has connectivity with Comcast and properly shows the guide, etc. Comcast sent someone out and confirmed that they "see" the box and don't have a problem. Any suggestions? Can I repair this? Thanks!!
Hello all, Well I bought the Phantom Motorola DCP-501 and my local cable company will not hook it...
(More)
Hello all, Well I bought the Phantom Motorola DCP-501 and my local cable company will not hook it up.. I tried 3 times to call tech support and I get 2 supervisors on the phone and I was lucky only my 3rd try I got a nice Tech person and I gave them the Serial # and they came back told me that your system is not in their system so they cannot hook it up, you must rent the Digital boxes from RCN cable.. Does anyone have RCN cable that hooked one of these boxes up?? SO I did file a Issue with the FCC today so I will find out about this issue soon I hope.. why does comcast supports this receiver but not RCN Cable.. they use the same DCT system? IF anyone has any info, please let me know studmaster91@juno.com subject line DCP-501 please. Thanks
