Question about JVC AV-48WP30 48" Rear Projection Television
Lot of red and double image
I just got unit from son. It has alot of red and double images. He ssaid something changed when we move it. Any ideals.
    Genius:
  • 1,139 Answers
Hello ford2tough,
This sounds like a convergence problem. try to use the auto-adjust first but if that fails try checking the voltage on the convergence ICs and compare them to the values on the schematic diagram. What may have happened is a cold solder joint just broke or even an over heat stressed track on the board (uncommon, but has happend). If this is a cold solder joint the problem can be fixed by just re-heating the cold joint. If it is not a solder problem then the ICs have to be changed.
Posted on Oct 24, 2007
SOURCE:
I own a hp 3700 dtn and i am having problems with the red color. It prints out a litle white or more like a orange then like red color. I guess it has to much yellow or a lot less magenta. I have changed...
first, in printer menu, there must be something like color calibration or adjustment, its auto procedure, try to do that and then print demo page.
Second it can be that the image transfer belt/roller needs to be changed or laser unit needs to be cleaned.
Hope that helps!
Jun 18, 2011 | HP LaserJet 3700n Printer
Tv is showing double images, not lining up
Your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option to align the red and blue colors
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Lots of red in pics otherwise great
If you have double image sounds like you have a convergence problem which is very common with these units.Part #STK392-110
Jan 12, 2009 | Panasonic PT-51HX40 51" Rear Projection...
DOUBLE IMAGES
there is a problem with tthe convergence section this is something a tech can do
Sep 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Panasonic Model No. PT-47WX42F
Replace the convergence amps. That unit takes two Sanyo STK392-110 and you could use 150's for greater reliability. Also replace one or more of the 1.2 ohm resistors in the yoke return circuit out front of the amps.
Oct 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 52"problem
You need to change the two convergence IC's - Generic part# STK392-110, Panasonic part# C5AA00000203. You might have problems using the generic #, I would use the Panasonic #
Sep 26, 2007 | Toshiba 46HM95 46" HDTV
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
37 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
