I can't open my hardisk by double Clicking, when I do so, A pop up window comes out, named OPEN WITH... what should I Do? and my files are being corrupted
Norton System Works may have a disk that will start your computer, fix problems, and then let you install an antivirus program. Norton Internet Security includes antivirus protection. I get mine from Purplus or Amazon, even e-bay, shop around.
Comments:
Apr 29, 2009
- I'm sorry you found my answer inappropiate. I'm not a salesman for Norton or anybody. It sounded like your computer was going down fast, and you were going to need serious help. I expect you have a computer virus, and are going to have to re-install everything after you remove the problem.
my playstation 3 wont read my iomega external hard drive, its 1TB. how can i make it so that it...
(More)
my playstation 3 wont read my iomega external hard drive, its 1TB. how can i make it so that it reads it.
My computer does't recognize CADB001U32 1TB HD after install/uninstall utility program? It says that...
(More)
My computer does't recognize CADB001U32 1TB HD after install/uninstall utility program? It says that I now have to Format drive? Had 368GB of space left on drive?
I'm having trouble connecting my Belkin wireless N+ router to a Western Digital Passport 500gb...
(More)
I'm having trouble connecting my Belkin wireless N+ router to a Western Digital Passport 500gb external hard drive. I have the dual USB input power cable from Western Digital (My Powerbook G4's USB port didn't supply enough power through a single port--the power cable uses both USB ports on my laptop which combine to a single Mini-USB output for the external HD). When I plugged the supplied USB to Mini-USB cable into both the router and the HD, it wasn't recognized (blue light remained off). I tried using the Dual USB power cable (one USB connected to the router, the other connected to an external/powered USB hub). The 4 port hub, which is roughly 8 years old, recognized the connection to the external HD (port 1 lit up), but the router didn't recognize anything plugged up via USB. So, my questions are as follows: Is this a power issue? Can I buy a newer, powered USB hub to resolve the issue? Would an ethernet hub be a better idea? I'd rather not shell out the $60 for the Belkin Network Hub if a simpler hub would suffice or if I already have enough equipment/cables to make it a functional connection. Is this a file format issue? I specifically bought the HD in the Mac format. Is that interfering with the router's ability to recognize the HD? I don't carry this external HD with me very often, instead, I prefer to use it as network storage. Thus, formatting this so that it is optimized with my network is more important than functionality as a portable HD. Any help/guidance you could provide would be greatly appreciated.
I have an external drive that has both USB and eSATA. The USB connection would work perfectly but...
(More)
I have an external drive that has both USB and eSATA. The USB connection would work perfectly but the eSATA won't be recognised. I already updated my BIOS but still... I tried disk management and while on eSATA the disk won't even be recognised as "being there"...
