Question about Creative Labs Zen Touch MP3 Player
Hard disc problem
I have had my player for over a year now and have not had any problems with it to date. Last Friday it went in to recovery mode and I selected the first option which was Clean Disk and it did not work. I then selected the option Format All and it returned a message Hard Disk Problem. Does anyone know what this means and what I need to do now? Please Help.
    President:
  • 4,402 Answers
Zen Touch and xtra hard drive error
"Hard-disk Problem"... I'd just like to confirm once more that smacking the player on its rhs while turning it on works.I had to smack it fairly hard though so don't be afraid!! I didn't try smacking it till I checked out the threads above so thanks everyone I'm a happy man again!! :)
Posted on Jan 07, 2008
No installation cd
Many newer computers have a backup reinstall program on a partition of the original hard drive. While booting in Bios hit F10 or F12. Your should get boot options as well as the Recovery Install option. Before using the Reinstall option try using the System Restore. The computer automatically sets restore points and you can select "Last good settings" restore point. In "safe mode" you can access more options in Accessories/System Tools/System Restore. There you will find other dates which you can restore to.
If you cannot boot you can use a manufacturers recovery disk. Unlike a MS full version CD the recovery disc will reinstall all software and hardware back to the state it was in when it was new. Depending how old your computer is, you may have to do many downloads from Windows Update.
You can get a recovery reinstall CD from the computer manufacturer, or check with friends if any have the same brand computer as their disc may be compatible with your computer. The discs are manufacturer specific and will only work on the same brand computer.
Apr 14, 2011 | Computers & Internet
I have a Sony VGC-RC310G desktop computer. Two nights ago, I was downloading updates for windows, from the Microsoft website. I turn it off when i went to bed, and restarted the following morning, only...
So, your description said that you turned off the computer during software update process, that sounds not good at all. Updates need to run to completion, or major failure happens.
You did not mention the version of Windows that you are using, so help is limited.
BE aware that a system restore means all data will be overwritten and lost. I suggest that you extract all data before you do anything. remove the hard drive and hook it up to a good computer, via USB and get all of your files and settings.
The machine probably has the restore files on the D:\drive.
Oct 22, 2010 | Sony VAIO® VGC-RC310G PC Desktop
HI I get error message 0XC000034 after booting computer I have tried to use A vista recovery disc but when prompted to press any key I get A message that says unable to get Bootlog If anyone can help Thank...
This problem is documented pretty well over the web.
It seems to be a sign of a hard drive problem. The first things that need to be done are as follows:
1 - scan the hard driver for errors. take it out of the computer and scan it on another computer.
2 - If no errors, back up all your important files.
3- If errors, Back up any file that it will let you and try to recover the rest with a data recovery progam.
4 - If error free after backup reinstall Operating System.
Jan 24, 2010 | Compaq Computers & Internet
Converting date of a month to last working day of the month
use the below formula to get the date of the LWD (Monday thru Friday) of the month.
Assumed that if the date in cell A1 is 6-May-2005. then formula will be
=DATE(YEAR(A1),MONTH(A1)+1,0)-(MAX(0,WEEKDAY(DATE(YEAR(A1),MONTH(A1)+1,0),2)-5))
Jan 30, 2009 | Microsoft Excel for PC
Can you help? Have a Advent 7096 laptop protected by PC Angel. Have run system recovery using 4 discs. Cannot get into Windows - message reads "load needed dll's for kernel" Not my machine but...
If you having problem running system recovery in normal mode try running system recovery in Safe Mode by pressing F8 key when you turn on the laptop.. a selection pop-up, select your primary hard disk where your windows installed still pressing F8 then a Boot Selection appear select Safe Mode after starting in Safe mode do the system recovery.. still not working choice the Last Good Configuration. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
Operating system
This will be either an operating system glitch of a failed hard drive. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If the hard drive will not format, or you have any issues during or after the install, then the hard drive has failed and will need replaced.
Sep 03, 2008 | Sony VAIO VGN-S460 Notebook
Hard Disk problem
replaced the hard drive. with a flash drive.
Replace hard drive
http://www.hardwarezone.com/articles/view.php?cid=9&id=1331
Mar 19, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Hard drive
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 10, 2008 | Creative Labs ZEN Vision:M Digital Media...
Randomly Went to Recovery Mode
The hard drive is bad and you will need to get it replaced. There is a repair service box on this page if you scroll down; just enter your zip code to find a repair service near you.
Aug 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen Touch MP3 Player Logo
131 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
