I have a touchscreen chinese psp SoRoo co. a product of lara tv games it's software is crushed in its manual &box they doesn't mentioned it's version,model No.&os so how&what software i should down load? help. me
Its supported os are WINDOWS XP/Vista. HOWEVER not to worry. Right click on the game icon and select properties. Click on the compatibility tab and tick the box in the compatibility mode section. Select either xp or vista and click apply.Stat the game and hopefully it works.
All i can suggest is a universal solution, use a pandoras battery for psp try this http://www.pspmod.com/forums/psp-hardware-guides/20964-pandora-battery-guide-noobs.html
First you're going to need a slim psp, if you have it then you just plug the cables to the right places. To play games on your tv you need a tv with progressive scan and component inputs.
Hi. I am Ashish from India. First check that Which part is not worked like the touchscreen or LCD? Was it damaged? If your LCD is damaged than replace it with new one with original or Chinese one. If your touch pad is damaged than change only touch pad not entire LCD and Touch pad. Than check your phone again. If your phone still give a problem than flashing the software. If you still have problem than mail me on [email protected]
First go to recovery menu by turning off your psp(not on sleep mode) and turning it back on with pressing R. then do to Configuration and change ur UMD Mode to M33 driver. then go to Advance then Advance Configuration. Everthing in there must be disabled. then exit.
