Question about Video Cameras
PLEASE SOLVE THIS PROBLEM
WHEN I INSERT THE CASSETTE IT SHOWS THAT RESET THE CAM TO SOLVE THE PROBLEM WHEN I RESET THE CAM IT SHOWS SEND TO SERVICE
  • 3 more comments
  • michelcuk Aug 24, 2008
    SAME
  • faser_m Sep 10, 2008
    i have the same probloem as this when i insert the screen it say it needs a service but some times it says incorrect function
  • Anton Pretorius
    Anton Pretorius Sep 12, 2008
    I have the same problem with three of my new Sony HVR- S270 cameras. On top of this the camera damges the tape when it eventually ejects.
  • Anonymous Dec 06, 2008
    RESET
  • Anonymous Jan 04, 2009
    I have the same problem. I do not want to pay for a service, I wan to keep using it until it stops then I iwll buy a new one.
    Problem Solver:
  • 10 Answers
Deassemble camera and clean four flexible connectors from mechnigm and re assemble it will work fine
Posted on Oct 29, 2008
Occasionally when it is riavvolge the tape it shows that reset the came.
Posted on Jun 25, 2008
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
I have a Sony Handycam DCR-PC100 that is now flashing an error code C:31:23 in the display when I try to play back the DV cassette in the video camera. Please advise what this code means and if the footage...
  1. Remove the battery or disconnect the AC power adapter for 60 seconds.
  2. Insert the battery or reconnect the AC adapter.
  3. Turn on the camcorder.
  4. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Try playing the dv casette on another player, it should be fine.
Aug 11, 2008 | Sony Televison & Video
Reset Minolta cs pro 3050 to Factory
Co920 - 1st cassette problem
Co910 - 2nd cassette problem
Co900 - 3rd cassette
Co950 - 4th cassette
Open and close the front after copier is ON,if the message is apper enter in the service mode,or pull out the cassette failure and work.
Service mode enter:press STOP - 0 - STOP - 1
Check the actuators in the cassette,feed rollers and the sensors.
Jan 08, 2013 | Minolta EP4000/5000 CS/PRO Copier
I can't watch back my recorded cassette, on my camcorder? i'm getting an error message C31 23
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Jul 24, 2011 | Sony Handycam DCR-TRV340 Digital Camcorder
My Sony DCR-TRV33 won't accept a cassette. It will close itself up without a cassette tape in place, but not while a cassette is inserted. I have tried several different tapes, so it is not the cassette.
Hi wnwatkins3,
Have the same problem here. Bought my TVR33 in 2003, and its still
a good cam with 1 megapixel. But since 1 month the tape won't load. I can insert any tape in the cassette, but it won't close. Without a tape it closes fine.
My only option is to send it to frsbenelux to fix it for a few hundred euros. Hoping to find a solution on the net, i will share with ya.
greetz Ed
Jun 29, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
Machine will re-wind but will not play or advance -- well it does a little and then the 'end of tape or no cassette' bar shows up on the display. What's wrong?
Hello Your unit needs to be send for service to be fix you can try to Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem they will service your unit
Jun 02, 2010 | Dictaphone 3750 Desktop Cassette...
Hi! I'm having issues with the revolving time traker thing. It just stopped. do you know hot to resolve this? Thanks.
Hello is real simple just press the reset button if this don't solve your problem it needs to send to service you can send it to Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Feb 08, 2010 | Olympus Pearlcorder J300 Handheld Cassette...
Wont load tape
HI, this is a mechanism fault beep you are hearing. the mechanism and load motor is damaged. you will need to send this unit to the Handy cam repair depot for this repair. you will need a new load motor and loading dock mechanism as well.
Jun 03, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sharp Viewcam VL-AH151U keeps saying "eject cassette" why is that? How or where can i send this to get fixed?
Assuming the record tab is in the correct position, download the manual for the VL-AH150U, very close to the 151U.
Page 10 of the manual shows the normal reasons for the "eject cassette" message. If not, I would call Sharp support at
1-800-BE-SHARP (237-4277) for referral to a local repair center.
Let me know if this helps.
Jan 18, 2009 | Sharp Viewcam VL-AH151U Camcorder
Video Cameras Logo
749 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
