Question about Samsung RS2630SH Side by Side Refrigerator
Samsung side by side rs21ncns1
The fride fan keeps making a noise. i keep having to strip the back of the fridge down and de-icing it. this happens about every 4-5 weeks.any solutions please.
  • kellys boy Oct 02, 2007
    I only speak english.
Go to Ebay and type the following in the search  Samsung Fridge FAULT
Posted on Oct 18, 2007
The FROSTY ICE is at the back of the fridge behind the lights.
Posted on Oct 16, 2007
  • 291 Answers
Is it a frost build up or ... ICE.. and IF ice where is it at?
If frost you have a defrost problem
Posted on Oct 12, 2007
SOURCE:
Hi Fridge side fan was noise for 3 days and now
Hi I have same unit. Problem is the fridge circulator fan gradually ices up, becomes noisy and then stops when frozen up.
To fix quickly you need to remove all shelves drawers etc, then unfasten lower panel fixings and find the whole back is full of ice including the fan.
Remove panel , and de-ice fan etc until fan rotates freely. Replace and all will be OK.
Otherwise empty and defrost normally but be prepared for a long wait
Don't call an engineer he will just do same. Hope this helps
Mar 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
MY SAMSUNG FRIDGE/FREEZER HAS A PROBLEM MY TEMPERATURE ON THE FRIDGE IS FLASHING. THE MODEL NO. RS21DCNS THE FRIDGE IS NOT COLD ENONUGH AND I PUT THE TEMPRATURE ON HIGH AND IMMEDIANTLY IT WENT BACK DOWN....
This is caused by the ice building up in at the back - the fan catches the ice and eventually will stop. With the fan malfunctioning the temperature will rise and the light then flashes. Keep searching the web, and you will find instructions how to remove the back and de-ice it. I had exactly the same problem 2 months ago. Make sure that it is fully de-iced, including the tray at the bottom. Ours has worked OK since!
Jul 07, 2009 | Samsung Refrigerators
Fridge has just started making loud noise and temp too high
sound like that you have a ice build up thats hitting your fan blade. Take and do a manual defrost on the frig side and be extra careful removing the cover in the back because there's 11 screws that have to come out before trying to remove the back poanel. Also if theres stillo ice in there what happens is that when you try to pull the back panel off it breaks off the stryrofam that samsung used for the air paths to cool the frig. so be extra carefull removing theses and if oyu do tear any and the airflow is not going the corect way you will drive yourself bonkers always defrosting htis unit. so heed my warning on this particular unit. its a great unit if you can psture what has to happen for the air flow to be correct. also put all of the screw back in correctly on the panel too. don't skip any because then the air flow is compromised. Good Luck and don't forget to rate the answer please. Haooy Neew Year!!!
Dec 29, 2008 | Samsung RS2534 Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Defrost issue... Kenmore refrig model ET8MTMXKQ00
This can be bad door rubbers but also the de frost heaters...
You should open the fride inside at the back and see fi the heaters dit not brake, also check the timer,thermostat,and the fan.
The fans realy importand,with out it working your fridge would turn into a ice maker.lol.
Let me know if you got it fixed....
Good luck.
Jun 19, 2008 | Kenmore 53542 / 53544 Side by Side...
Fridge fan noise
Du musst den Abtausensor erneuern, ((Gelbes Kabel ))
Jun 03, 2008 | Samsung RS2534 Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Noisy F&P fridge freezer
Most of f&p make this noise its most annoying, but could also be ice buildup on the fan blades, creaking and cracking is normal as the pipes expand and contract is these thin foamwall fridges, not nice fridges, insulation has been compromised to lower cost, they work twice as hard at keeping cool
Jul 27, 2007 | Fisher and Paykel Active Smart E522B...
Noisey fridge/faulty fan
Hi Fat head; the problem is not completly uncommon. what can happen is the fan gets something on it and becomes unballanced. Thi in turn wears the fans motor bushings out, and eventually ruins the unit. A couple hundred quid seems a bit steep to me, But I live in the U.S.A., and unless I am mistaken, the cost to have a repair person come, and do a service on an electrical appliance, is considerably higher in the U.K. So no, a couple hundred quid is not completly out of line. Best regards; HELP2DIY
Jul 10, 2007 | Samsung RS2630AWW Side by Side...
My fridge won't keep temp..
most samsung have a fan in the fridge and an evaporator. take off the back plate of the fridge and melt off and excess ice especially round the fan.; if it keeps happening then you have a fault in the defrost system
May 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
309 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
