Question about Gateway GT4010 (RBGT4010) PC Desktop
AMD processor? My computer died "slowly"...while using it the picture slowly darkened so I shut it off. Then when I tried to put it back on, there was no power...nada, no sound, no lights, nothing. I removed the cover, cleaned out the incredible amount of dust accumulated inside and around the fans and now the power goes on but nothing else happens. Has the processor overheated? I would like to try and repair this myself if possible. If it is the processor, where would this be located in a GT4010? would anything else be affected.. cards, chips? Thanks for any help.
  • Sanstar Sep 30, 2007
    Thanks so much for your quick response. I will look into your suggestions and try doing a little home mechanics. If it turns out to be easier than said, I may even upgrade.
    Again, many thanks!
    Sandra
    Guru:
  • 120 Answers
The processor is located under the large fan that is attached to the heatsink (large aluminum cooling device). The fan/heatsink will be located on the board itself, so it's pretty easy to locate. You should just need a flat head screw driver to unlatch the headsink from the board (be very careful not to slip, there should be a small piece of metal on the clip to secure the screw driver as you press down to unlatch it). Another thing to take a look at is the power supply. Just because the power supply turns on doesn't mean it's supplying enough power. Try going to the store (even walmart) and picking up a new power supply. the wattage of your old power supply (PSU) will be listed someplace on the side of the PSU inside the case. You probably have between a 300 - 400 watt power supply. If you can't find the number, try picking up a 350w power supply. It should take you no more than 5 minutes to unplug the cords of the old one and plug in the cords of the new one. You literally can just set the new one beside the computer and plug the new cords in, no need to completely install it. If this doesn't help, then you've ruled out a power supply failure. As long as you've kept your receipt pretty much any store will return it for cash. If this doesn't work you can pick up a replacement processor for your system pretty cheap off ebay. If it does turn out to be a processor, put some consideration into upgrading to a faster processor. Your system has a amd athlon 64 3400 inside currently, you can purchase atleast a 3800+ instead and make it faster. Good luck Peter
Posted on Sep 30, 2007
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
My AMD 3200+ 400/333 chip has died, what can I replace it with? The motherboard is an Asus A7N8X.
Anything in AMDs Socket A line of processors should work.
The AMD Athlon XP 3200 was one of the best processors that would work in that board. Good luck finding one though.
Oct 10, 2009 | AMD Athlon XP 3200+ 400MHz FSB CPU...
New processor for my compaq presario sr1810nx
for better gaming performance u need a Graphics card of nvidia or abt 4 gb of ram....bt 1.8 ghz processor can't  go smoothly with High performance Games...so its better to change ur motherboard instead of wasting money on such things becoz only selected games will run on 1.8ghz processor...KSHITIJ
Jun 17, 2009 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Asus A8N SLI DELUXE MOTHERBOARD AMD PROCESSOR
When you reinstalled the processor, did you put thermal compound on it? Not putting thermal compound on an AMD processor could burn it. I've tried this before, thinking it was okay since i tried an Intel not placing any thermal compound, and there was burning smell on the AMD processor. If the problem before was the power supply, you might also want to check the motherboard. Defective power supplies destroy the motherboard as well. You may also want to check the if the power button was placed back to its pins. You may have missed that or the wire might have come loose.
Sep 13, 2008 | ASUS Computers & Internet
No picture
you may have turned down the screen control
It is the lower one on the flyback transformer
Just advance it enough to get the pix back. If you advance it too much it may get retrace lines in the pix or shut down.
turn very slowly.
Thanks Guy
May 10, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
AMD Athon XP 2600 dropped speed
Some times when a computer shuts down unexspectedly like that it will reset itself back to its defaults in bios thinking there was a problem. Go in there and check your cpu settings. The fsb should be set to 266 mhz. Make sure it didnt default back to 133 mhz.
And FYI the 2600 is acutally a 2.13 gig cpu not a 2.6 gig..
Mar 02, 2008 | AMD Athlon XP 2600+, 2.08 GHz...
Compaq Presario AMD Turion 64 X2 Dual-Core TL-56
it hates the taste of the memory you put in.
use
2GB 667Mhz DDR Memory
Jan 25, 2008 | AMD Turion 64 X2 TL-56 CPU
Amd 64 3000+
Hi Rhen, I did some research and found this on avid.com: "As far as problems you will encounter, Pro Tools used to have a problem where it wouldn't work at all on AMD systems without disabling DEP In Windows. Supposedly, the problem was related to the ILok drivers, and so with these drivers http://www.paceap.com/dldrvr.html you should be fine with Pro Tools and AMD." I hope this helps.
Aug 26, 2006 | AMD (SDA3000BOBOX) Sempron 3000+, 2 GHz...
Gateway GT4010 (RBGT4010) PC Desktop Logo
96 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
