Question about Microsoft Xbox 360 Elite Console - Black
X box 360 broke
The disk tray was out on my console and my kids knocked it off of the tv stand.i got the tray to go in and out again,but now it wont spin the disk.im still under waranty but i just got it back after a mnth and a half due to the three red light thing and dont really want to send it out again.i just waited in line till 1am to get halo three and now cant play!easy solution?reset or something?plz help!!!!!
Send it in *******
Posted on Dec 21, 2008
    Problem Solver:
  • 9 Answers
The only solution really is to open your 360, open the DVD drive and try to see if you can posibibly unfreze the drive. Its possible that you are going to have to put a new drive in it. I would just send your console off, even though you'll have to wait on the Halo experience. If you do open your console, you're going to void your warranty and Halo may cost you a whole 'nother $300. When and if you open your console, you will need to check if the laser is operational. With the console open (check Google for a huge list of how-to-open-it guides) go on ahead and remove the cover from the DVD drive, but keep the DVD drive still placed in the Xbox 360. Hook-up your power and video cable and go ahead and press the eject button (you can place this back on without putting the console back together, even though its ness. to take it off during the disassembly) and watch the tray. Listen and watch for any resistance, stuttering, swaying to one side (hold the console flat), and scraching. It should be very smooth and automatic. Then procede to close the tray but this time watch the laser. Don't look directly over the laser, but try to catch if it lights up (red) and it may even move a little at you. Again, everything should be smooth and automatic. Now for the slightly tricky bit. Take the worst possible game in your collection (King Kong?) and place it on the open tray (open tray, place disc on tray) and then close the tray. Hold the 360 as flat as possible or don't hold it at all (the latter option is better if you have a table nearby) and watch the disc, always ready to press the eject button if something goes wrong and your disc spins out of control and/or you hear scratching. An alternate, safer method of checking to see if the disc spins is to take a fridge magnet and place it on the center spindle magnet and let the disc spin (the magnet, just like the one in the DVD drive cover, hold the disc in place as it spins at super-sonic speed!). Just use the very simple process of emiliation to determine the root cause of your DVD drive problems and then repost. Just remember that this voids your warranty and only open your console if you're sure that you want to try to fix it and you are willing to accept that you may be left with a brick afterwards. That's it for what you should do to diagnose the problem, good luck!
Posted on Oct 01, 2007
SOURCE:
Wont play games just says reading, open tray.reading, open tray. reading, open tray.u get picture
Xbox 360's disk drive is starting to fail.Knocking on the top of the Xbox (when its on its side) while loading a game cansometimes get it to work, but at some point you will need to have your Xbox repaired by Microsoft or replace it.
Apr 23, 2011 | Microsoft Xbox 360 Console
Xbox 360 Console: my xbox 360 won't read a disk...
First the disk has probely has something on it or a scratch. Second the disk slot you might have to blow inside it so any dust can't get on the machine where it reads the disk
May 16, 2010 | Microsoft Xbox 360 Console
As soon as i turn on my 360 the disk tray light wont stop blinking and disks wont read
Listen close and see if you hear the tray motor running. If you do then, most likely, the belt and pulleys that move the disk tray are dirty. Which might also explain not being able to read disks. Here's what to do: Pull the face plate off of the 360. This will NOT void your warranty. Beneath the disc tray (look under and "into" the tray) you should see a gear wheel on your left side. Push eject. Use a toothpick (or similar object) to turn that gear from left to right. Keep turning and the tray should pop open. Unplug (WITHOUT turning off) the 360. Pull the disk tray to full extention and look through the slot in the center of it. You'll see the belt and pulleys. Tweeze the belt out small pulley first clean the belt & pullies w/alcohol. Put belt on big pulley first. Then run a lens cleaner disk when you get it opening again.
Nov 24, 2009 | Microsoft Xbox 360 Console
Old xbox360 disc tray wont close at all
open it up ( very carefully) and check to see if the disk tray end is still attached or alligned to the plastic gears that eject the tray. if so check the rubber band to make sure it has not broke or streched.
Jun 25, 2009 | Microsoft Xbox 360 Console
Unable to read disc (of any kind - games etc.
ok my friend had this problam all i did was check tha disk port seen it was off a bit i took a screw driver and pushed it in and down we heard a pop now not only do's his 360 now read disc's it also dosent scratch any disk's now eather: oh yeah this is mainly caused by you 360 standing up right every time it accidently falls over it knockes the disk tray lil by lil out of socked
Jun 13, 2009 | Microsoft Xbox 360 Console
Game disk
in that x-box the supported file may be did not installed properly or it will ask the required disk inside in your dvd to console the games
Apr 17, 2009 | Microsoft Xbox 360 Console
Xbox 360
When your son knocked the console over, he may have broke a component connecting to the disk drive, especially if the console was on.
Apr 11, 2008 | Microsoft Xbox 360 Console
Accidentally knocked the disk tray out of my friends xbox
Out of your what?  360?  How did you accidentally knock out the disk tray!?
Please explain with more detail!
Dec 06, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console - Black Logo
119 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
