Question about Philips Magnavox 51MP392H Rear Projection Television
How to fix my 54" Magnavox rear projection tv
I am having 2 issues with my tv: 1) I have a vcr and cable box with surround sound tuner on top of my tv. There are green lines going down the screen, sort of blurred and randomly placed. How do I fix this? 2) I have tried everything on the remote and menu to bring the tv into focus. When I pull up the guide the words are just barely out of focus. nothing on the menu or remote will bring it into complete focus. Is there something else I can try to make the image and words clearer.
ACS module is bad hard to find vertually impossible, throw away your tv buy a new one.
Posted on Oct 09, 2007
The Cable connection is broken, how do I replace it? the model is D52W26
Thats called the f-fitting or rf fitting. Its attached to the tuner on your set. You can either replace the whole tuner circuit or in most cases, replace the rf fitting with a new one as long as the tuner board was not damaged. We stock the fitting which are like 2 dollars a piece so I would think alot of tv shops would stock them. You could expect to pay around 125.00 or so depending on your location to have it done in your home. To do it yourself you will need to be handy with a soldering iron and be extremely careful in the tuner area not to damage surround coils..
A cheap or maybe free alternative is if your using a cable box, to just hook it up using video and audio patch cables which will bypass the TV tuner altogether. If you still have a vcr you could use it for tuning or buy a cheap converter box (as long as it has video and audio outputs) at most any local dept store.
Just run patch cable one yellow for video and the other 2 are red and white from the box to the tv. I think the boxes are around 25.00 or so
Oct 19, 2010 | RCA P52926 52" Rear Projection Television
Sony VHS model no: SLV-SE710G isn't recording now that we have a freeview box. It just keeps changing back to L1 whenever i try to record anything!! I only want to record channels 1,2,3,4 !! HELP!!
Its hard to work out without looking at your cables. I assume the problem started when the freeview box got set up. I would guess that the aerial cable is now in the set top box instead of the vcr as the vcr sounds like it is unable to record when there's no signal (a common feature) so there shouldn't be a fault with the vcr,
just unplug the aerial from the set top box & plug it back into the vcr. Ch 1 2 3 4 should be back on vcr but set top box wont have any Ch.
most set top boxes have an aerial output, so you'll need another aerial cable, plug this into the aerial input on the vcr & ch 1 2 3 4 will be there but these will be analog (if your area has stopped analog transmission thats the prob rite there)
If you plug the matching cables from the set top box into L1 on vcr you'll be able to record digital tv as L1 use a signal from another tuner eg set top box, dvd player whereas the vcr channels 1 2 3 4 use the vcr's built in analog tuner. so it shouldn't be a biggie another cable should fix it,
Hope this is helpful, ask if you need more info
Aug 20, 2009 | Sony Televison & Video
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
I can work on cars but not tvs
THIS SET'S TUNER MAY BE BUILT IN THE CIRCUIT BOARD--QUICK FIX-IF YOU HAVE A SATELLITE OR CABLE BOX---USE THE VIDEO/AUDIO "OUT " AND PLUG IN THE TV'S A/V INPUT(1OR,2) THEN SWITCH TO THE AV FUNCTION ON THE TV AND YOU SHOULD HAVE PICTURE AND SOUND...WHAT WE ARE DOING IS BY-PASSING THE BROKEN TUNER...HOPE THAT WORKS ..IF YOU DON'T HAVE SAT OR CABLE BOX,,YOU CAN USE A VCR--THEN YOU HAVE TO CHANGE CHANNELS ON THE VCR....TUNICA
Sep 22, 2008 | RCA P52926 52" Rear Projection Television
Sound
Three (3) possible ways:
1. use the audio out of the TV (if available) which would normally be red/white RCA and connect to any of the free INputs of your DVD surround sound system;
2. remove the cable INput of your TV and feed it to a tuner such as those in a VCR or any other device (some DVDs have TV tuners also). The VCR's Video OUTput would go to your TV while the Audio OUTput would go to any of the free INputs of your DVD surround sound system;
3. if your cable uses a box/decoder and has the yellow, red & white RCA, its a matter of splitting the red/white signal to feed both your TV and DVD surround sound system or simply remove them from the TV and feed them to the DVD surround sound system.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Televison & Video
Split screen question
Only if you have 1 Ant input, if you have ant 1 & 2 then you don't need a vcr for split screen.
Feb 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
MAGNAVOX MWC24T5
Do you have a cable box? if so unplug and plug back in the box. I do have issues with boxes doing that, try unplugging the tv also. what have you done to try to fix it?
Jul 08, 2007 | Philips Magnavox 20MS233S 20" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
383 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
