Question about Sony KP-53S65 53" Rear Projection Television
Sony Wega 34 inch Tru Surround DRC MF
Hello, My problem seems simple enough; just that I am not sure if the solution is also equally simple. I have this TV for 3 plus years, and lately it just doesn't start. The standby light flashes 10 times before it pauses. I am told this is to with a power problem. I have unplugged the TV a few times and it used to start again, but now even this doesn't seem to work. Please help. Cheers
  • snoza Sep 07, 2008
    i have the exact problem flashes 10 times and getting to start it seems to get longer by turing it off and on
    whats the g board and can i solve the problem myself or do i need parts what do i do when i check these's numbers you suggested and what do i look for?
    Sergeant:
    Champion:
  • 346 Answers
Check q8014 and q8013,r8051 and ic8005 on d board
location is seen under the green printed circuit board
Posted on Jan 01, 2008
SOURCE:
232 of 245 is what percent?
Well 245 times 0.947 equals 232.015.
Is that close enough?
(approx. 95%)
Jun 16, 2011 | Texas Instruments TI-83 Plus Calculator
I want to create an if else statement with regards to this problem for ms excel 2007. the conditions are if month>=3 plus 1/2 but if not then minus 1/2.
It seems to have botched your sign before the =3 but lets say that you used "less than" or equal to 3.
(if you used Greater Than, then simply replace "less than" with "greater than" in the example here)
The easiest thing to do is subtract 1/2 no matter what and then say if month is less than or equal to 3 then add 1.
this way, if the month is NOT less or equal to 3, it has already subtracted 1/2, satisfying the "if not" part.
If the month IS less or equal, it adds 1 which compensates for the 1/2 we already subtracted, plus another 1/2 giving an end result of plus 1/2.
This makes it a simple, single if statement that is satisfied in the other direction without having to overcomplicate the issue.
Apr 27, 2011 | Microsoft Computers & Internet
I'm looking to get help with the equalizer settings on my Philips 47 in LCD TV. It just doesn't sound very good....Need help
hello,
Philips 47PFL7403D have Equalizer: 5-bands
Output power (RMS): 30W
Sound Enhancement: Incredible Surround
Sound System: Dolby Digital (AC-3), BBE.
Mar 27, 2011 | Philips 47PFL7403D 47 in. LCD TV
There is a series: 8,6,17,35,30,71,_,143 what will be the number in the blank space?
8 plus (-2) equals 6
6 plus 11 equals 17
17 plus 18 equals 35
35 plus (-5) equals 30
30 plus 41 equals 71
71 plus X equals Y
Y plus Z equals 143
Not much of a pattern in the "differences".
8, 17, 30, X
6, 35, 71, 143
No pattern there.
8, 6, 17
35, 30, 71
X, 143, Y
8 + 6 + (3) = 17
35 + 30 + (6) = 71
No pattern there.
Dec 24, 2010 | Core Learning Aptitude Builder Full...
One number is 11 more than another number. Find the two numbers if three times the larger number exceeds four times the smaller number by 4.
Do you need help doing your homework?
If so, here's a first attempt. It may be correct, and it may not be.
It's up to you to understand the process, and to make any needed corrections.
X minus 11 equals Y.
So, X is larger than Y.
So, 3 times X minus 33 equals 3 times Y.
Thus 3 times X equals 3 times Y plus 33.
Also, 3 times X minus 4 equals 4 times Y.
So, (3 times Y plus 33) minus 4 equals 4 times Y.
Thus 0 times Y plus 29 equals 1 times Y.
So, Y equals -27.
Dec 10, 2010 | Computers & Internet
What is the answer to 10x minus 3x equals 20 plus 1 equals what
joshua,
X = 3 (answer)
Here are the solution steps:
10X minus 3X is 7X (right?)
20 plus 1 is 21 (right?)
therefore:
7X = 21
now divide both sides of the equals sign by 7
7X divided by 7 equals 21 divided by 7
7X / 7 = 21/7
X = 3 (answer)
More math? Ask for Gort007
Thanks for trusting FixYa !
Sep 14, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
On the TI-84 Calculator I can't find the = symbol. Not the enter key to find the answer to a simple equations. But if I were to use the Solve(...) option in the Catalog I can't because I can not find the =...
Since you know about the catalog, that is where you find the equal sign, near the bottom of the list. It is faster if you scroll up from abs(.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Calculator
Hello, I have an RCA Truflat tv that I bought
If you can hear sound and the sound coems from your TV, try changing the volume with teh TV remote control. Your TV isn't off it is still on. Just the video board or portion is cutting out. this could be a ton of things, I would try changing out the power strip or plugging the tv into the wall directly to make sure it has enough power. other then that you can try a home brew solution like putting a fan next to your tv to cool the component that seems to be overheating and shutting down your picture.
Aug 25, 2009 | RCA Televison & Video
How do I on a TI-84 Plus Simplify Fractions
Enter the fraction for example: enter 8/12.
The answer will be .666666
Then click Math (which is located under the Alpha button).
Click the ->Frac button (the first one).
It should come up as Ans->Frac.
Click Enter.
It should now read 2/3 which is 8/12 reduced.
Note: I have a TI-84 Plus Silver Edition, and the TI-84 Plus might not have this function, but that is how I do it on my TI-84 Plus Silver Edition
Nov 08, 2008 | Office Equipment & Supplies
Sony KP-53S65 53" Rear Projection Television Logo
662 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
