Question about Labtec Webcam Pro
Help please my webcam and my mic on my webcam work realiy good but when i go onto msn the webcam works but the mic dosnt can you hel me please i need it urgentally
You might not have downloaded the software properly. try again and see what happens.
Posted on Mar 15, 2008
Check the settings on your msn that the input is set to the mic and also on the sound in control panel that input is set to labte mic
Posted on Nov 25, 2007
SOURCE:
Hi, plz i need your help, i have a camera lifecam vx-500, but in my msn the camera ist out, do you helpme???
Set your webcam mic (if it has one as default)
Vista - If you have an earlier OS, you may have to access your hardware from the Control Panel.
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Aug 06, 2010 | Microsoft LifeCam VX-1000 Webcam
Well i dont have a webcam on my laptop so i plugged this in, but it wont let me use it.
In the webcam world things are not quite that easy - you need to download drivers (software to make hardware work) and then configure the webcam to any chat program you want to use it in
1) download the driver from here
http://www.bioticaindia.com/pdc-301.html
An example of setting up a cam in msn
Plug in the webcam
TEST SPEAKERS
Restart computer
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Aug 06, 2010 | Polaroid PDC 301 Webcam
I have a logitech webcam STX which does not work on windows live messenger It formerly worked well and no changes made to my computer except adding a program which scans and "repairs errors" once a day ...
Plug in the webcam
TEST SPEAKERS
Restart computer
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Aug 06, 2010 | Logitech QuickCam Messenger Web Camera
I can't make my webby work with msn. it works off
Plug the webcam in and set your webcam mic as default
TEST SPEAKERS
Restart computer
Vista -
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Jul 15, 2010 | Microsoft LifeCam VX-1000 Webcam
Installed Philips SPC630NC web cam will not display picture on Msn Messnger live just a green screen, all drivers have been checked and software but just a green pictur, it wont work on any other cam site...
Vista
TEST SPEAKERS
Restart computer
Vista -
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Jun 15, 2010 | Philips SPC 630NC Webcam Fun - Web camera...
Well I have a msi laptop and the built in web isnt working and I checked if it was on and it says it is. But when I go to skpe or msn nothing happens and the little light beside it doesnt go on? I need...
You will have to set up or configure your webcam software to work with any chat program before you can broadcast.with it.
If it has a built in mic with the webcam -Make it your default mic.
TEST SPEAKERS
Restart computer
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Vista -
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Jun 13, 2010 | Computers & Internet
I have logitech webcam logitech mic but cannot get the mic to work through windows live webcam works
Typical audio set up
Laptop x webcam/mic x Vista x MSN Messenger
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
CONFIGURE TO MSN MESSENGER
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Click 'Finish'
Jan 10, 2010 | Logitech QuickCam Communicate STX Personal...
I have the same problem
MIC SET -UP VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET MIC DEFAULT & TEST
Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Re-start Computer.
CONFIGURE TO MSN
Re-boot the webcam by unplugging and plugging it back in again - Its always good practice to do this before you open MSN. If you have been using your webcam in another program, it can remain hooked up to the old program and you will get an error message " Unable to find webcam or being used elsewhere"
Webcam Connected
Open MSN
Click ( > ) Open Menu >Tools > Audio & Video set-up > Set mic as default and run through audio set-up > Next > set webcam as default and adjust Webcam Settings > Finish
Aug 13, 2009 | HP VGA Webcam
Mic on msn wont work
your cam and mic need to set up with the msn
After you start Windows Live Messenger,
expand the view by clicking on the square
on top left next to the red X.
Then on the Windows Live messenger window on the
right side, click on “ “Show Menus.” And then click
on “Show the Menu Bar”.
Next go to the Menu Bar on right side, click on Action.
Go to “TOOLS” and click “Audio and Video Setting
and follow the instructions.
please let me know if this has solved and don't forget to rate
Feb 13, 2009 | Logitech Webcam
Labtec Webcam Pro Logo
50 people viewed this question
Top Labtec Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
