Question about Compaq Evo N110 Notebook
WONT BOOT WHEN I TURN ON LAPTOP, ITS SAYS UNMOUNTABLE BOOT VOLUME HOW TO I FIX THIS
    President:
  • 2,961 Answers
If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable. If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support. If it's a damaged file system case then:- 1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted. 2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console. 3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console. 4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER. 5.At the command prompt, type chkdsk /r , and then press ENTER. 6.At the command prompt, type exit , and then press ENTER to restart your computer. This takes a bit longer, but the system should boot back into Windows.
Posted on Sep 30, 2007
    Scholar:
  • 84 Answers
Here is a link to Microsoft which includes steps on how to correct this issue Hope this helps you http://support.microsoft.com/kb/555302
My ibm thinkpad will not start up, even in safe mode. unmountable boot volume keeps coming up
Hi there.
Remove all usb flash drives or external hard drives connected to the laptop.
If no flash drives or external hard drives are present the you will need to reboot your system and press the delete key repeatedly until you get into the BIOS. Once in the BIOS you will need to locate boot disk priority. Set priority 1 to the laptop's main drive and priority 2 to the CD/DVD drive.
Now it should first try boot on your hard drive with your operating system on it. If after this you still get the unmountable boot volume error then your hard drive may be corrupt.
~ Slasher_X
Sep 25, 2011 | IBM ThinkPad T42 Laptop
Unmountable boot volume
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
Latitude D400 Laptop- unmountable boot volume
there a hard disk problem, probably has no hd-disk. you must reclaim for a new working hd.
Jan 02, 2010 | Dell Latitude D400 Notebook
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Sep 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
check your harddisk is detected in bios .
otherwise u have to repair winxp with bootable disk.
Also try to go to recovery console if u have bootable win xp disk.
then type "chkdsk /r" in rercovery console
then it fix error on harddisk and u cna login in winxp
May 20, 2009 | Computers & Internet
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Jan 11, 2009 | HP Compaq nx7010 Notebook
Will not load windows I get an error message stating unmountable boot volume
i) i think you hard disk or hard drive(of your laptop or desktop) is malfunction or not working properly.....
   or it has gone bad, i think you have to send it for repair or replacement;
   error messge: unmountable boot volume is specifically for harddisk malfunction and requires repairing or replacement(strictly)
Thanking you
M. Sridhar
Dec 29, 2008 | IBM ThinkPad 600E 2645 Notebook
Cant get on.
Please follow the directions at this site:
http://www.rm.com/Support/TechnicalArticle.asp?cref=TEC71448
Of course, this assumes you are using Windows XP.
May 15, 2008 | Toshiba Satellite A55-S1063 Notebook
Compaq Evo N110 Notebook Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
