Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dripping from the water dispenser on freezer
Model # TFX20JRB oN MY SIDE BY SIDE REFRIGERATER THE WATER ON THE WATER DISPENSER KEEPS DRIPPING EVEN WHEN I MOVE THE SELECTOR TO ICE.
  • 290 Answers
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
Posted on Oct 06, 2007
  • Anonymous Oct 24, 2007
    Just wanted to follow up and see if you were able to get a service call set up.
    Thanks/Mike
    SOURCE:
    Water dispenser leaks on model number KSRS25FGSS13. I HAVE FLUSH THE AIR OUT AND IT STILL HAS A VERY SMALL DRIP
    Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
    May 10, 2010 | KitchenAid Architect 25.3 Cu. Ft....
    Water dripping out of water dispenser tube
    SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
    Jan 12, 2010 | Kenmore Refrigerators
    Outside ice despenser is dripping, no ice
    water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
    ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
    If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
    Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    How do I get the water dispenser on the outside of the door to quit dripping water
    Jun 30, 2009 | Whirlpool ED5FTGX Side by Side...
    Kitchenaid model ksrs25ilss02 water filter
    Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
    is dripping from the ice dispenser, it is because the rubber gasket
    is bad on the flap that seals after ice is dispensed. If water is dripping
    from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
    Mar 27, 2009 | LG LRSC26940ST 36" Side-by-Side...
    Kitchen Aid Super Ba refrig..water dripping from water spout !
    To stop the dripping now, turn the water off.
    The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
    Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
    Water keeps dripping after it dispenses water thru the door
    When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
    Since all this is inside the door, you will either have to take it apart to see/fix/replace.
    Quick fix: turn down the water pressure coming in(?)
    Call Mr. Handyman to fix.
    If under warranty - they might fix this for you for free
    If this is a factory defect, there might be a recall in place for repair/replacement parts
    Googlee both - Make/Model + Dripping Valve + Recall
    Good Luck!
    Jan 17, 2009 | Frigidaire FRS3R5EMB Side by Side...
    No water flow
    turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
    Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
    Water dripps
    IF THE WATER IS DRIPPING OUT OF THE DISPENSER NOZZLE THEN YOU NEED TO REPLACE THE SOILINOID BECAUSE IT IT LEAKING THROUGHT THE VALVE..
    Sep 21, 2008 | Samsung RS2534 Side by Side Refrigerator
    GE (PSS26MSRSS) Side by Side Refrigerator Logo
    1,416 people viewed this question
    Top Refrigerators Experts
    Brad Goodale
    Matt Sicignano
    Level 1 Expert
    JP Meneide
    JP Meneide
