Home | Acer | Aspire E360 PC Desktop | No power response, cab...
Acer Aspire E360 PC Desktop
Problem for Acer Aspire E360 PC Desktop
No power response, cable and outlet are good
By medothere on Apr 28, 2009
There is no response when i press the power button. It's a good outlet and we've tried another power cable. I guess it just needs a new power supply, but if that's the case, I do not know what criteria to base that purchase on. Any groundbreaking insight?
Solution #1
posted on Apr 28, 2009
Not Rated)
louislevel_2
Rank: Guru
Rating: 88%, 208 votes
hi there,
have you seen or heard the fan moving,if that so it may be power supply,unsle you have a tester
to measure the output supply from power supply. try to open the cover of your cpu on side corner there are two lock in bolt,loosening this and slide pull backward to open,on figure as sample the location of quick lock bolt.
then inside your cpu,you can see power supply
there is a specification tabulated on side of pwer supply.on figures you can see.on the arrow pointing power supply. on your cpu you can read the specification
of your power supply take note on this.when you buy new power supply just let them know,mostly
the capacity they will ask you e.g. 450 watts.have a nice day,don't forget to rate me.
ps
removing power on figure you can see cable from power supply going to mother board disconnect them from terminals such as hardisk,cd room.floopy,motherboard,and the sccrew on the backside of cpu.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire E360 PC Desktop
Questions and Unsolved Problems for Acer Aspire E360 PC Desktop
Do you recommend Acer Aspire E360 PC Desktop?
Answer
Answer
How do I connect hP e9240 to direct tv to use my multimedia software
Answer
Require Packard Bell Easynote R1938 disassembly instructions
Answer
How do I get my Namco all-stars pac-man game to use a gamepad instead of the key board? I can't get... (More)
Answer
Hi. I'm using a Asus M2N-E motherboard and when I do a CMOS HDD's start to spin Fan of VGA Processor... (More)
Answer
GA-8TRC410MNF-RH Hello, I have given this motherboard and I know the position of the panel... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire E360 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
