Question about Gateway M275 Tablet PC
Gateway tablet screen does not respond to pen.
My pen for my tablet has stopped working with the screen. it has for 20 months.
  • 4 more comments
  • AXNJXN Dec 18, 2007
    My screen stopped responding to the pen, and i tried using the solution previously mentioned (piece of paper in he bottom left hand corner), and it worked, but now it has stopped working. I opened the inside frame around the screen, cleaned the edges of the screen, but it didnt help. Any other ideas? Iamactionjackson@yahoo.com
  • Anonymous Jan 04, 2008
    I have the same problem, I have restored the software but the pen continue without working. In some papers i red that the pen has electronics inside and maybe it was the probem
  • Anonymous Apr 11, 2009
    I have gateway computer, I turned the screen off, then after 1 hour I tried to turn it on, it is not responding, but the computer is OK
    Please HELP
    Can someone tell me what to do
    Please HELP
  • Anonymous Mar 16, 2014
    Screen flickers when you press lightly on the back it turns the screen off how do I open the tablets back to see if the battery is loose
  • Anonymous Mar 31, 2014
    Haier Tablet
    Haier Tablet
  • 4 Answers
I have a Gateway CX2724 and previously had another Gateway tablet (model I don't remember) but they both look alike and use the same pens. I've had 3 pens and they all periodically stop working. When one stops, I pick up another pen and work with it so that makes me think the problem has more to do with the pen. (They have all died and later come alive.) Sometimes though I can't find the extra pen and have resorted to removing the working pen tip / nib and reinserting it very snugly after wiping off the shaft. The nib is held in merely by friction. You can remove it by pinching its little tip between your fingernails and pulling it straight out. I wipe off the shaft and put it snugly back in. Sometimes I don't take it out, but just press it harder into the pen by pushing it firmly onto a padded surface (so that the tip doesn't deform.) Usually one of these "treatments" works. I know that extra nibs are available with the pen. There must be some reason that the manufacturer thinks they may need to be replaced periodically. But I've never seen any documentation on this.
Posted on Feb 03, 2008
Another website like this one said that the the problem is metalic crude shorting out the digitalizer. Sure enough I pressed litely on the screen's lower left hand corner to form a small gap between the frame and screen and the pen worked again! Be carefull not to press to hard or you may crack the screen. I ran a piece of thick paper,more like thin coated cardstock around the edge between the frame and screen to get at any little bit of debris there and I am now using the pen to type this note here. It is taking several swipes of the paper to get all the biuldup removed but the process is a success!
Posted on Nov 24, 2007
    Habit-Forming:
    New Friend:
  • 23 Answers
OK, THIS ISSUE DRIVES ME INSANE! I NOW HAVE 3 SURFACE PRO 4 PENS BECAUSE I CAN'T JUST BUY THE TIPS WITHOUT BUYING A NEW PEN AT BEST BUY FOR $80 EACH TIME SO, I HOPE THIS HELPS YOU, WHAT I DID WAS GO TO THE MICROSOFT SUPPORT BLOG SITE OR SOMETHING LIKE THAT I'M NOT A COMPUTER PRO SO BEAR WITH ME , AND FOUND THIS OUT IF YOU POWER DOWN YOUR PC THEN HOLD DOWN THE POWER BUTTON AND VOLUME UP BUTTON FOR ABOUT 15 SECOND IT WILL BOOT UP THEN YOUR SUPPOSED TO POWER DOWN AGAIN AND THE PENS SUPPOSED TO WORK BUT IT DOESN'T ALWAYS. THE LAST TIME I DID A COMPLETE SYSTEM RESTORE WHICH GOT MY PEN BACK FOR A DAY AND NOW IT'S GONE AGAIN....VERY AGGRAVATING!!!!
Posted on Nov 30, 2017
If it's the pen it's self... There is a one cell battery about the same size as a 'AAA' a little slender.
Posted on Feb 09, 2008
Pen is off target the futher you get away from the center of the screen, especially at the edges. calibration is no help
Posted on Jan 16, 2008
Tablet pc pen isnt working its moves around when i put hte pen to the screen but its like theres no pressure it wont click
A common problem with touch screens on Palm Pilots is contamination getting under the edge causing pressure that fools the screen to thinking there is pressure under the lip of the bezel. There MAY be a similar thing with your tablet PC.
Jan 09, 2010 | Gateway M275 Tablet PC
My slate vision tablet pc is having some problems. The screen is not reacting when the pen touches the screen. I went into the control panel seems that everything set up correctly. Could it be the pen that...
Your tablet pc uses the Wacom Digitizer so the pen does not use a battery. It is possible that it could be the pen or the screen. It works with electromagnetic resonance technology and the screen produces this signal that the pen grabs, converts, and returns to the screen without batteries. The pen does contain compenents that can fail but so does the screen. You could try buying a replacement pen for around $20 dollars and see if that works. Worst case you would be out $20. If you had another tablet PC that uses a Wacom screen you could try the pen with that one or test the other pen with yours.
Sep 28, 2009 | FIC SlateVision Tablet PC
My pen for my computer won't work
I think the pen has gone bad on you, since your screen can still detect your hand and the track pad. I would think the pen is faulty. Try another pen cause I think your original is bad, if it was the touch feature that wasn't working I would say its a driver problem but that feature still works with the exception of the pen. Get another pen.
May 31, 2009 | Dell Latitude XT Laptop Computer Tablet...
Gateway tablet cx200X, tablet features won't work/ pen etc
All, There is DEFINITELY A PEN IN THE CX2620 stylii. I just replaced mine with a AAAA battery. The old one (which is a AAAA size, you can find these inside 9-volt batteries) had acid buildup on its positive end and that is why the pen went inactive. There is a lot of debate over this pen problem and I guarantee 90% of the time it's related to the battery. I can do a clean replace on anybody's CX2620 pen/stylii with a fresh battery for $10. If interested email me at [email]kevinteman@hotmail.com[/email] . You pay for shipping, your total about $17 or so. I have never done this before but I just replaced mine flawlessly so I can do others. I know there are a lot of dead stylii out there and people don't know what to do, took me a while to figure it out.
Thanks, Kevin Teman [email]kevinteman@hotmail.com[/email]
Feb 13, 2009 | Gateway CX200X Tablet PC
Tablet PC 2005 Input Panel won't work.
Are you pressing down firmly enough? If not, sounds like the digitizer may have a problem... The digitizer is the layer in front of the lcd, it's job is to pick up the signal from your pen and send it to the motherboard. The motherboard should have two connections to the screen, one to the lcd itself and another to the digitizer. If you remove the screws on the bottom of the tablet you can take off the keyboard and see if both are connected right.
Oct 18, 2008 | IBM ThinkPad X41 Tablet PC
Tablet 2724 pen issues
maybe your screen is messed up ... try borrowing a pen from a friend that you know works
Jun 22, 2008 | Gateway Tablets & eReaders
Gateway Tablet PC Pen gets stuck in pen holder
just take it to the vendor because it is having warranty
Apr 28, 2008 | Tablets & eReaders
Touch screen not working
Have you tried a new battery in the stylus? They require AAAA size batteries. The first time my pen went out I thought it was the computer not responding, but it turned out to be a dead stylus battery.
Mar 21, 2008 | Averatec C3500 Tablet PC
Thinkpad tablet pen problem
It could be a problem with the pen but I am not positive. I knew someone who had a problem a little different from this but involving the pen not working how it should. They called the company they got the laptop from (Gateway in their case) and they were sent a new pen for free. Lenovo might do that if it's under warranty or you could buy a new pen. It could be a problem with the drivers, though, in which case I am not entirely sure what to do. Maybe reinstall?
Nov 30, 2007 | Lenovo ThinkPad X60 Tablet PC
Problem with pen/software on Gateway M280E
First install the anti virus software then update the software then scan your computer after scan try again. if it cant work format your computer.
Sep 03, 2007 | Gateway M280E
Gateway M275 Tablet PC Logo
4,915 people viewed this question
Top Gateway Tablets & eReaders Experts
rongg
k24674
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
