Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Card error On the screen reads card error. this come up when I tturn my casio . The above message is in a small orange square
  • Jerry May 11, 2010
    What type of SD card are you using in the Casio? Is it HDSC? Did it just start doing this or did you just purchase a new SD card for your camera?
  • 289 Answers
Try turning off the camera. While it's off remove and reinsert the memory card. If the same message appears, you should re-format the memory card. CAUTION: Formatting the memory card will delete anything on it. Copy the files off of it before formatting.
Here is your manual:
http://support.casio.com/pdf/001/EXZ60_e.pdf
Posted on Apr 28, 2009
SOURCE:
How do I fix my Casio ce-6000 cash register it reads FErr20 on the screen
Many times error messages on a camera can be corrected by disconnecting the memory components. Turn off your camera and completely remove the battery and the memory card from their designated slots. Leave it off for a few minutes and then turn it back on.
Jul 22, 2011 | Cameras
Casio EX-Z55. When a memory card is in camera, the screen reads 'card error' and the camera is unusable.
http://www.casio.com/support/techsupport/0FA55BD6-45AA-4F2D-9C44-1292D0BD0D91
The above says to try another card. If that doesn't work try to send the camera in to Casio.com for evaluation.
I wish you luck in repairing this camera.
Aug 06, 2010 | Casio Exilim EX-Z55 Digital Camera
My calculator fx-991 Es is showing either syntax error or dimension error while finding out the inverse of the matrix although the matrix is a square one
How about recreating the error and reporting faithfully the error message? You get a syntax error if you try to invert a matrix by using the wrong key sequence such a
[SHIFT][MATRIX][3:MatA][X to ] -1), meaning that you use the universal power key on the same row as X squared and log and between them.
To calculate the inverse of a matrix, have the name of the matrix on the command line, (see above) then press [X to -1] key one row up from [log].
Concerning your implied affirmation that if the matrix is square you should not be getting any error: You will get an error ( a Math error) if determinant of the matrix is equal to zero.
Mar 13, 2010 | Casio FX-115ES Scientific Calculator
What do i key in for 2 to power of 12??
Between the x`squared key and the log key there is a key with an x with a raised small figure of a solid square. That is the key you use to enter arbitrary exponents.
  1. If calculator is in MathIO ( a Math indicator appears on the upper band of the screen), enter the base of the power (here 2). A number 2 with a raised empty square appears.The cursor will blink in the raised square. Enter there the exponent (here 12) and press [=]. Result 4096 appears at the bottom of the screen.
  2. If in LineIO (no Math indicator appears on the narrow band at the top of the screen), press 2 and then the key I talked about above. On the screen a number 2 appears with a hat and a left parenthesis. Type in the exponent (here 12) , the right parenthesis and press [=]. The calculator should display 4096.000...
Hope it helps
Nov 17, 2009 | Casio fx-300ES Calculator
2 to the twelve power equals what
In the exemples above I used 2^12. But you can enter any base (2, 3, 5.5, 16/47, ) and any exponent ( 12, 13/48, 0.007654, even negative values).
Hope it helps
Nov 17, 2009 | Casio Office Equipment & Supplies
The card is locked appears on screen when SD card is inserted
Is it possible for you to use some tweezers and adjust the very small lever inside the camera's card bay? It may be stuck thus telling the camera the card is locked.
Aug 27, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
What does PICTURE ERROR mean? not in manual nor on line
Sounds like you will need to format the memory card as the card has become corrupted. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the picture error message and the card can be used again.
Dec 29, 2008 | Olympus SP-500 UZ Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
437 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
