Question about Fuji FinePix S5000 Digital Camera
Camera does not work
When I turn on my camera to take a picture I can't see through the viewer.....I only get a blue screen that says NO IMAGE...and there is a small arrow in lower left corner pointing to the right.
  • 1 more comment
  • ebssoc Oct 02, 2007
    It is on "take pictures" and on "Auto".....I took to a Fuji Repair shop yesterday ...He said he thought the switch felt sticky......He thought 95% that the problem was the switch.....but I didn't leave it there ....too far away.....where can I get the switch fixed? betty
    Thanks Dyllan ...i'll see what I can do....thanks for getting back to me....if I decide to get a new cheap camera (with warranty) which one do you suggest? Betty
    thankyou
    Sergeant:
  • 279 Answers
It looks like your camera is set to playback mode - and it's trying to display pictures you've taken previously, except you haven't taken any. There are two controls that adjust this. One is the power switch. It has three settings - off, playback and take pictures. You'll want to move it past the playback (which is a triangle) to the take pictures (which is a small picture of a camera). There is also a wheel on the top of the camera that adjusts your picture mode. Make sure that's set to AUTO. I found a user manual that goes into this in more detail here: http://www.fujifilm.at/Support/Manuals/FPS5000Manual.pdf It's right at the beginning - there are 2 pages that tell what all the buttons, switches and knobs on the camera are. I'll also upload the manual to Fixya so others can have access to it. If you have any further problem with this, just post it here - I'll do my best to help.
Posted on Oct 02, 2007
  • John Goodman Oct 02, 2007
    Any camera repair shop should be able to do it. Most electronics repair places probably can too. I'd avoid any place that just does computer repair, but if they work on other electronics it should be no problem.
    You COULD order a new switch from Fuji and try to replace it yourself. It's probably a mechanical, rather than electronic, problem (some tiny piece of plastic is worn out or broken). However, once you took the thing apart, putting it back together could be difficult, so I'd suggest taking it to a professional.
    If you can't find a place locally, let me know and I'll see if I can find some place you can mail it to for repairs. But a local place would likely be faster, and would be more accountable (because you can show up on their doorstep).
    I'd say it's almost definitely the power switch though, just not switching all the way over to pictures.
    Honestly, I'm probably not the best one to ask for buying advice. I can help fix them - but I haven't priced or compared them in quite a while.
    President:
  • 2,961 Answers
Sorry, but in a finepix camera, no image normally relates to when you are viewing the pictures you have taken and not in the shoot mode, applogies if i'm wrong, but theres seems no others are posting a solution.
Why is there just a black screen in eye view?
sir,
can play your cassette? if the picture is clear in play back mode,then there may be problem with the image sensor (CCD) in the camera,open the camera, measure the voltage at the CCD board if the voltage is not correct check the fuses on the mother board.
Feb 06, 2016 | Sony Handycam DCR-TRV250 Digital Camcorder
My camera works fine for awhile, and then the screen goes dark, but you can still see some movement. Pictures turn our dark with blue tint. I've tried charging the battery, and battery appears to have a...
This sounds like a problem with the image sensor within the camera. I doubt camera charge will affect picture or LCD screen image quality. Such problems can occur with old camera and in most cases buying a new camera is indicated as repairs are expensive. Ask at the Casio website support.
Please rate Fixya Answers.
Feb 18, 2011 | Casio Cameras
Camera operates but produces black image. shutter
I have the same problem. Have you fixed it yet? If so, would you mind sharing what you did to fix it? Thanks!
Aug 10, 2010 | Fuji FinePix S2 Pro Digital Camera
No image on the viewer; no image being recorded.
If your Canon A80 camera shows previously stored images of memory card in playback mode but does not show live view in camera mode to take fresh picture then ccd imager chip got defective and need to be replaced.
Local camera repair shop will help you to replace ccd imager chip because camera will take apart in detail and soldering work is needed.
Thanks.
Jul 14, 2010 | Canon PowerShot A80 Digital Camera
Mode switch has broken off and the camera screen says no image
it probably remained locked on the viewer and there are no images capture stored into the camera ..that's why it says that ....and it must be a way to restore the function of that button cause no matter if you lock it permanently into the the shooting mode its still a issue of getting pics out of it ....most cameras have to be on viewing mode when are plugged on the data cable ...but ..if you can open it and switch it on the mode that allow you to take pictures...you can always get the pictures from the SD card directly via an card reader ...adapter ( USB) that cost only a few dollars...
Aug 07, 2009 | Canon PowerShot S500 IXUS 500 Digital...
My screen is not working
The 35mm Canon DSLR cameras don't have that option like lower end point and shoots. The image must be captured prior to viewing.
Sep 13, 2008 | Canon Rebel XT / EOS 350D Digital Camera
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
No image
79da3bf.jpgWhile in picture taking mode, press that button. It will restore your viewer.
Nov 20, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
65 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
