Question about Kenmore Elite HE4 Electric Dryer
Cycle signal is going crazy
My Kenmore Elite dryer still dryes most of the time but I am having trouble with the dryer signal. It keeps sounding about 20 times a minute while the clothes are drying. I am unable to turn off the signal, computer not responding when I press the button. Sometimes when I try to stop the signal from beeping the dryer shuts down and will not turn on . I unplug the dryer for a while and then I am at least able to start it up again but the beeping continues. No error codes have popped up yet. Is there a way to reset the computer?
  • speedybullet Sep 01, 2008
    End of cycle signal goes from off to high to low about 20-30 times a minute. While doing so, none of the other control functions will work. After it cools off for about eight hours, it will start up again but same thing happens with end of cycle signal going crazy. It is drying the clothes well. I checked the vent - all is clear. Dryer is 1.5 years old. The control panel was replaced after I had it less than one month.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Check vents and venting. sounds like a controller problem and unfortunatly there are no resets for that type of problem
Posted on Jan 02, 2008
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
I havea kenmore elite drye it wont start the lites are on but its just not starting
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 19, 2010 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite washer cycle signal keeps going off an on turing cy
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2009 | Kenmore Elite HE4 Electric Dryer
Cycle Signal Beeping
The user interface button panel has failed and will need to be replaced.
Apr 19, 2008 | Kenmore Elite HE4 Electric Dryer
Loud/Soft signal
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
May 25, 2007 | Kenmore 67052 Dryer
Kenmore Elite HE4 Electric Dryer Logo
338 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
