Question about Alpine CDA-9856 CD Player
Load problem and error message
My cd player doesnt have a cd stuck in it, but it wont accept any cds in it, and if i press the eject button, it just whirs and makes noise like there is a cd in it, and says "load". then it just says "error". the only way it will accept a cd in it is if i were to push eject first and then it would suck in the cd, but im afraid it will get stuck so i dont. any ideas?
  • 227 Answers
Re: Load problem and error message
Did you try to reset it? Look for a small button that only be press with a toothpicker or something that small. Another way to reset is to disconnect the battery. Goodluck.
Posted on Mar 10, 2008
0 characters
3 Points
My cd is stuck in the player, i get an error 6 message when i try to eject it or play it
have u tryed holding the eject button for ten seconds my clarion does the same thing but it should eject the cd
Mar 05, 2010 | Clarion DXZ438R CD Player
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD Changers
The disc magazine is not inserted in the cd changer
No disc is inserted in the disc magazine
The disc is dirty, or the disc is inserted into the disc magazine
upside down
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
Jun 14, 2009 | iLO CA3000V CD Player
Stuck cd
press & hold the eject button
Feb 07, 2009 | Alpine CDA-7863 CD Player
Radio works fine, put in a cd and it ejects it.
Unit will not accept
a disc
CD mechanism position out of alignment Press EJECT for 3 seconds to reset CD mechanism position
CD transit screws still in place Remove 2 transit screws located on top of the unit
You can down load the manual here at this site.
Good Luck
Please rate at FixYa!
Dec 19, 2008 | Dual XDM6825 CD/MP3/WMA Player
Sony CDX-L480X
I had the same problem, CD not accepted by unit and pressing source button to select CD player causes unit to display reset.
Using reset button just causes unit to 'whir' for a while, problem is not solved. Firstly with unit switched off, and the ignition off I inserted a CD using some gentle force, I then inserted a second CD, forcing it in over the top of the first. Next I pressed and held the reset button for a short time before releasing it. Both CDs were ejected, when the unit had stopped I took the CDs out, replaced the front panel and turned on the ignition, The unit will now accept CDs and eject them O.K.
(This did take two attempts to get right). Seems to reset the eject status of the CD player.
Feb 17, 2008 | Sony CDX-L480X CD Player
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
Feb 08, 2008 | Alpine CDM-9803 CD Player
Wont eject
not getting enopgh power to cold warm it up leats 30 min driving befre use car in cold
Feb 04, 2008 | Jensen CDH-1000 CD Player
2001 Mustang 6-disk CD player
does it give an error code? usually it just a gear timing problem, will it load discs that are in it?
Jan 02, 2008 | JVC KD-S680 CD Player
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
May 18, 2007 | JVC KD-SX770 CD Player
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Alpine CDA-9856 CD Player Logo
370 people viewed this question
Top Alpine Car Audio Receivers Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Jeff Turcotte
Jeff Turcotte
Are you an Alpine Car Audio Receiver Expert? Answer questions, earn points and help others
