Question about Funai SYLVANIA® DVL1000G DVD Player
Funai drb2737 please can you help me im after the code that can turn the player to play region 1 as we have alot of disks from this region and currently cant play them thanks claire
  • ccubed73 Dec 18, 2007
    i want to unlock the zones on my funai as i bought in the uk and have moved to australia and cant play dvds on it
  • WILLIAM JOHN CALDWELL Apr 22, 2009
    looking to unlock my funai to play region 1 or O;
    model is funai combi drv. b. 2737
I would like to unlock my funai as i have a dvd in america and it wont play on my dvd player can you help ??
Posted on Jun 22, 2008
SOURCE:
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 23, 2010 | Audio Players & Recorders
I have a philips DVP 5150 DVD player that only plays Indian disks but not from US. Pl help how to dezone this dvd. Naren
HELLO
Try This!
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You'll The current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all
regions
8. Press the "Play" button on the remote.
Hope this helps you (:-)
Oct 09, 2009 | Televison & Video
Can a region 1 DVD be played in australia
DVD-VR330: region free
1.Turn DVD player on without a disc inside
2.Hit 'MENU' on remote control
3.Enter code: 57538
4.The current region code will be displayed in the top-left corner
5.For region free press 9 (region 2 UK, region 1 US etc)
6.Power OFF and power ON
Remember your region code that displayed.Some disks sold in your area will only play if your unit is set to your region.In that case go thur process again and instead of 9 put your region number in.Need more help [email protected].
Aug 22, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Change dvd player region to multi region
Try this procedure
. Turn on the unit
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
Dec 05, 2008 | Philips DVP5140 DVD Player
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
REGION 2
1/ Power ON
2/ Press PLAY
3/ 274222222005255
4/ Press Play
5/ Power OFF
Apr 22, 2008 | Yamaha DVR-S150 DVD Player
CODE REGION
Turn the player on and open the disc tray. Press [CLEAR] followed by [1][3][6][9] and one of the keys [0]...[8] corresponding to the region you want to set the player for (1 for Region 1, 2 for Region 2 and so on, press 0 for Region 0 or Region Free). Turn the player off then on again for the changes to take effect.
To verify the region code, press [SETUP] followed by [1][3][7][9]. A screen will then pop up with the firmware info and the current region code setting. Using [SETUP][1][3][6][9] did not work for me.
Or
To modify the region, turn on the unit and open the disk tray. Using the remote, press [CLEAR][1][3][6][9][zone code] and cycle power on the unit (not necessary to unplug the unit, simply use the front left <POWER> button. Example: Turn on; open tray; [CLEAR] [1][3][6][9][0]; unit OFF, unit ON and you'll get a zone free DVD player.
To confirm the zone code, turn on DVD player, (unit may or may not have a disc, check that the disc tray is closed, and press [SETUP][1][3][7][9]. You'll have all the firmware information (Version xx.xx.xx.xx SUB-VER xx.xx.xx.xx;
8032 xx.xx.xx.xx; Servo xx.xx.xx.xx; RISC xx.xx.xx.xx; DSP xx.xx.xx.xx; Region Code 0) That's that final "0" that you are looking for!
Mar 17, 2008 | RCA DRC247N DVD Player
Hi I need to unlock my Sanyo DVD player HV-DX350A
HI this works as i have unlocked my own Sanyo HV-DX350A player with it Hope it works for you
Unlock region code for Sanyo HV-DX350A DVD/Video player.
1. Turn on unit
2. Select DVD
3. Open tray
4. Press 0520 then in sequence press arrow up, down, left and right.
5. The region management screen is displayed on your monitor ( Code is displayed on the unit LCD display).
6. Note - Your current EEPROM region code setting is displayed on the screen.
7. Enter desired Region Code ( 0 for multi region).
8. Press PAUSE to exit.
9. Turn power off and turn on again.
If you repeat steps 1 to 4, you can view your new setting.
Feb 29, 2008 | Televison & Video
Region code for Samsung DVD-V6700
1. Make sure there is no DVD in the drive. The player must be empty. Turn on the player, (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the USA ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 29334
Nov 15, 2007 | Samsung DVD-909 DVD Player
Funai SYLVANIA® DVL1000G DVD Player Logo
355 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
