Question about Sharp 27C-240 27" TV
Sharp 27G-S60 Set comes on with all audio & video OK, then in about an hour picture folds to a horizontal colored line. Sometimes all the way across or sometimes just in the 50% of middle screen. I can note picture info inside the colored line. Do not know where individual circuits are located in set. ie: vertical osc, horizontal osc etc. Can you advise circuit diagram availability or visual help to troubleshoot on web? Help greatly appreciated..Ron
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is cery simple as it folds after an hoyr or so. as you are asking for the section where the problem is located so is in horizontal oscilattor section.(possible cause cap.might be defective.) as per ckt diagram is concerned is concern please seeweb site www.serviceinfo.com hope this will help
Posted on Oct 02, 2007
SOURCE:
I have a Sharp Aquos LC-60LE650, no picture or sound with various flickering lines, mostly horizontal. Lines come and go, sometimes moving across screen. Any help? Picture included.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 27, 2015 | Sharp Televison & Video
Sharp tube tv 1998. Comes on momentarily, then picture fragments starting at top and bottom at same time. Final indication is a thin bright horizontal line across mid tube, then internal circuit breaker...
The most likely cause of the issues is bad electrolytic capacitors.
Not worth fixing IMO.
Tracking down and replacing the caps would be many hours work...
Nov 20, 2017 | Sharp 27SC260 27" TV
Only a horizontal line can I see in my TV
In most cases the vertical output IC and possibly a fusible resistor off of the high voltage transformer are bad. The vertical output IC is located on a heat sink and usually right next to the vertical yoke winding connectors that are green and yellow in most sets. Please take a moment to rate my answer..Thanks...
Nov 24, 2009 | Sharp 27G-S60 TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Sharp TV model 27H-S60 convergence
HI ,USE A PATTERN GENERATAR DOT OR LINES TYPE AND USE THE CONVERGANCE RINGS BEHIND THE YOKE OF THE SET ,THERE ARE THERE RINGS FOR EACH COLOUR RED GREEN AND RED .SLIGHTLY MOVE THE RINGS AND U CAN SE EIN THE PATTREN THE COCLOUS WHICH IS FRINGES EACH BY EACH U ADJUST ALL THERE RINGS FOR PERFECTION , FIRST LET THE SET BE SWITCHED ON FOR 1 HOUR AND THEN DO THE ADJUSTMENT. THANSKS
May 22, 2008 | Sharp 27H-S60 TV
Sharp 27G-S60 TV analog or digital?
Call 1-800-237-4277 1-800-BE SHARP
FAX 1-630-378-9981.................................................
Oct 21, 2007 | Sharp 27H-S60 TV
Sharp 27G-S60 no vertical picture
your problem is due to vertical section failure.
 as you say it was intermittent for a while, but now is permanent
please check the followings as given
  • remember you should keep brightness as low as possible to avoid crt burn.
  • there might be loose contact in print or connector loose for deflection coil.
  • check supply to vertical output section
  • check components in vertical output section like electrolytic capacitors & low value resistirs.
  • check verical outout ic .
  • hope this will help
  • good luck.
Oct 13, 2007 | Sharp 27G-S60 TV
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Sharp 27C-240 27" TV Logo
107 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
