Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
MY WD64 does not spin
Hi, I just moved my washer dryer and it no longer spins, the motor does not come on. Is there way to test motor to be sure something is wrong with it.
  • lali001 Oct 02, 2007
  • lali001 Oct 03, 2007
    I did not mean to yell but I am seeing your responses as though I am some idiot. The machine is reconnected in same place the same way. When its on it does not spin even dummy like me knows this narrows problem down to motor or control for motor, I posted here in case there is a common problem known on these type machines.
    Looks like I'll have to scrap it since control or motor are both 100 each.
  • 1,294 Answers
First see if there is power in your wall socket; then check your washer plug, or plug fuse, wires.......
Posted on Oct 01, 2007
  • prem mathew Oct 03, 2007
    When u type in capitals, you are yelling at me!!
    Note that the outlet tube is not connected to the drain at floor level; it should be at least the machine height; the machine pumps the water OVER this height. Or the water will just drain out......
    Yelling gets you nowhere.
I have a Kenmore elite he5 gas dryer and when it is turned on it will not spin. Can you tell me why?
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings OTHER WISE CHECK FOR A LOOSE WORN BELT
Feb 15, 2015 | Kenmore HE5 7.0 cu. ft. Super Capacity Gas...
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Rattle or leaking condensor on Hotpoint WD64
This website has been good to me so I thought I'd post back!
A common problem with the WD64 washer dryer is the condensor working itself loose from the heater box on the top of the machine. This will result in terrifying banging on spin and, if left, screws and rubber seals appearing under the machine. If left longer, as it was with my own, the machine will leak from the condensor to backplate joint at the back of the machine.
The problem is caused by poor fixings at the condensor (the white plastic piece) to the heater (the silver box at the top of the machine).The solution is to remove the condensor, clean it and refit it with new more robust fixings. Hotpoint provide their workmen with a kit of heavy duty bolts, but I did it with a few loose bolts I had. Save all rubber parts as they are riduculously expensive to buy. I had to by the o-ring from condensor to drum backplate and could only get 5 at silly money. If anybody wants one at a good price I'm kolleykibber on ebay.
on Jan 23, 2009 | Hotpoint Aquarius WD63 Front Load...
No spin
make sure the belt is on first..then check the filter.. if all was ok ..test the motor with a multi meter
Apr 19, 2014 | Whirlpool Washing Machines
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 01, 2010 | GE WSXH208A Front Load Washer
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD64 is not spinning or emptying
check the pump, make sure drain hose is not cloghed, ensure the belt is in the place, spin the drum a bit by pulling the belt. then give it a go.
Update me about your progress
Jul 24, 2009 | Hotpoint Aquarius WD640 Front Load...
Won'i\t spin or agitate. was working fine-went
if agitator movement is weak or moves in only one direction check the following:
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt(belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
If drum does not spin check this:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the drive belt (belt drive only)
  • Test the motor
Good luck !!!
Jul 11, 2009 | KitchenAid Washing Machines
The agitator on my ingis liberator is no longer working
Try to do this
Good luck !!!!
Jul 08, 2009 | Washing Machines
Kenmore stacked W/D will not agitate during wash cycle
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
Mar 31, 2008 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
144 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
