Question about Frigidaire FRS23R4A Side by Side Refrigerator
Intermittent Loud Whirring Noise
There is an itermittent load whirring noise coming from the freezer section (almost behind the icemaker). During the time it is making noise, the in-door water dispensor will occasionally not work and the icemake not produce ice.
  • msbridges Nov 14, 2007
    This is exactly what is happening right now. Very frustrating.
  • 291 Answers
Sounds like the evaputaor fan motor.. may need to replace.. check to see if anything maybe hitting fan blades
Posted on Oct 01, 2007
SOURCE:
Whirring noise from mitsubishi dion
Sounds like you have a defective wheel bearing.
Jun 07, 2013 | Mitsubishi Mirage Cars & Trucks
Loud whirring noise going into rinse cycle. Low
Hi tuck just read your posting.Now on the low whirring noise on the start of the rinse cycle ,Is it when the machine is draining the water or filling with water.If the noise happens when the machine is draining then I think either your pump has something slowing it down or it is faulty.Please look underneath the machine to the front right and you should see a red or black fan .If you do then this is your pump.If you don't see a fan you must have the newer style of pump.Please reply with additional information on the questions and I am sure I can help you rectify this problem
Jul 08, 2010 | Fisher and Paykel GWL11 Top Load Washer
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
I found and fixed loud whirring noise in freezer
I m not sure what your asking . so let me try . you corrected your problem . and it's working . i think it's great. now in a couple of day's it may do it again. generaly if you have ice build up like you described . then you may have a defrost problem.if you do . then you must correct it . the heater / or timer or thermo may be out . so if the problem comes back /get me the brand & moder #.. **** hope this helped mm
Dec 17, 2009 | Kitchen Ranges
Our LG bottom freezer refridgerator is 2 years old. It is making a whirring noise that stops when the door is opened. It can get pretty loud at times.
The whirring sound is the fan that blows cold air into the refrigerator. It is supposed to stop when the door is opened. If it is making a loud noise there may be ice built up in the fan housing. Turning the power to the refrigerator off for a 2-4 hours may allow any ice in the fan to melt. If you do not open the freezer during that time the frozen food will not defrost.If the noise continues, you may have to take the fan apart to make sure it is not frozen. It is probably located behind the back inside panel of the freezer.
Nov 02, 2009 | Refrigerators
There is a really loud whirring noise when it
The Color Wheel in the Optical Engine is what is most likely causing the problem. It is a very expensive part and I would call Toshiba at 1800-631-3811 and see if they could help you with the cost and also referring a Service Repair Facility to you.
I hope this helps,
Skyassoc
Oct 25, 2009 | Toshiba 52HM95 52" HDTV Projection...
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
My psp makes a loud whirring noise
Hmmm... well i think its because its thea game or something or that you need to clean the PSP because when you open the UMD drive dust could fly in there or the UMDs might have dust inside and attract more dust but your able to play games right?
Jun 19, 2008 | Sony PlayStation Portable (PSP) Console
Frigidaire FRS23R4A Side by Side Refrigerator Logo
973 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
