Question about HP OfficeJet V40 All-In-One InkJet Printer
Printer "holds on" to card stock at the bottom of page
When printing on card stock, the printer starts off perfectly. When it get to the last few lines, the printer "holds on" to the paper the prints them on top of one another. I have checked the rollers in the back of the machine, turned it off and on, cleaned some things; to no avail. Help!
    Genius:
  • 3,587 Answers
Yes..depending on the card stock, that can happen quite frequently. you may find that one at a time is needed, or placing a thinner sheet of paper, between the sheets, can help..most printers don't have ability to manage varying thicknesses of paper, unless printer settings are changed.
no worries..start by getting new driver for that here
Posted on Feb 28, 2008
SOURCE:
HP Photosmart C4795. Can't get business cards to align correctly at top. Alignment is perfect on plain paper, but starts too high on card stock so every one is lined up wrong. What am I doing wrong? Using...
In printing properties and printing preferences be sure and tell the printer you're printing labels, it allows more time for the card stock to reach the starting point.
Jan 05, 2010 | Office Equipment & Supplies
Print wedding announcements and the print is not straight
Card stock on an HP can be a nuisance, due to the paper feed path. The stock has to curl around the platen.
Some things to check: Make sure you are telling the print driver you are using card stock. It should be in the printing preferences as paper type. The printer will respond differently, knowing it has the heavier paper. Also make sure that your paper guides are adjusted to fit the smaller stock. Just putting in 5.5 x 8.5 paper into an 8.5 x 11 tray may cause it to skew.
I am assuming that you are already telling it to print high quality, as it is for a wedding announcement, but make sure that you are. Slowing down the paper feed speed by putting it into high quality mode can help.
Your printer is an older model, so it could be that the rollers are wearing down, and it just can't feed the last bit as well. You could try to print it in "landscape" mode. Turn the paper 90 degrees in the paper tray, so that the 8.5" is the feed side. This will allow the printer to have a better grip on the paper as it goes through. A word of caution with this method, though. HP's have a 1/2 inch margin at the bottom of the paper where it can't print. Turning the paper 90 degrees will force you to have a side margin of 1/2 inch. Currently, your bottom margin has to be 1/2 inch. I don't know what your layout looks like, so I don't know if you can turn the paper.
If you are the one getting married, the congratulations, good luck, and mazel tov! (Have to cover all the basis).
Jul 17, 2009 | HP DeskJet 5550 InkJet Printer
Prints 2/3 of the way, stops, continues, bottom is faded
It sounds like you need to replace Toner Cartriage
May 19, 2009 | Samsung ML 2010 Laser Printer
1: the paper jams when it tries to print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 11, 2009 | HP DeskJet 712c InkJet Printer
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
Printing on templates
This is normally set through the page margins within the software you are using not the actual printer settings. MS Word has templates for various Avery labels, but I've found after loading the template you have to fine tune the margins for your printer. Use plain paper to print test pages and hold them over your card stock to check alignment.
Dec 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
Hp Printing issue driving me INSANE!
use a smaller card stock in size so it will come out smoothly.
check also the page setup that you're using give some allowances.
Oct 20, 2008 | Office Equipment & Supplies
HP OfficeJet V40 All-In-One InkJet Printer Logo
166 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
